Old 25-03-2006, 10:32 PM   #1 (permalink)
Default a good mobo required
hey guys
can anyone please tell me which is a good board for me
it must have the following features
LGA775
4GB DDR400 support
atleast 4 SATA
PCIE slot(MOST IMPORTANT)
1 IDE
ATX
preferably based on 915
my budget is rs4000
makarand is offline
Old 25-03-2006, 11:03 PM   #2 (permalink)
ymhatre's Avatar
U can have asus P5rd1-VMbut problem is its having max 2 gb of ram support
rest all is taken care of @ 3250 Rs
and i still guess 2gb of ram is enough for next three years...
In 915 series i tried searching for this.... but problem is tht either it is having 2 gb of ram or the prize is above 4.5ks
so i guess wht i sugested is good choice u check the specification @ http://in.asus.com
i guess wht i suggested is good choice
Plus its having onboard ATI X200 with Radeon 9600
so graphics r also good iat medium level.
at the most u can go or p5 RD2 - vm having a 1GB ethernet.....
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 26-03-2006, 01:32 AM   #3 (permalink)
have u already bought the CPu or what?
ashnik is offline
Old 26-03-2006, 07:12 AM   #4 (permalink)
yes i have already bought CPU
its an Intel 2.67GHz
also anuzzer question
what is the likely FSB of my CPU
makarand is offline
Old 26-03-2006, 07:36 AM   #5 (permalink)
ymhatre's Avatar
ur FSb of cpu is 533 im 90% sure of this but then too u can check it in bios...
Do u currently owe a motherboard. if yes which????
DusT = ME
ymhatre is offline
Old 27-03-2006, 08:13 PM   #6 (permalink)
what d'u mean by owe a motherboard?
did u mean own a motherboard
makarand is offline
Old 27-03-2006, 09:12 PM   #7 (permalink)
darklord's Avatar
you can get Asus P5GPL board for around 3500 i guess,not sure.
Its based on Intel 915PL chipset,full ATX,nice board.
darklord is offline
Old 28-03-2006, 11:43 PM   #8 (permalink)
ymhatre's Avatar
sorry i did mean own one sorry
and but P5rd1/2 is better than p5gpl...
here u will atleast get a good onboard VGA...
DusT = ME
ymhatre is offline
