Old 25-03-2006, 01:27 AM   #1 (permalink)
Default How to connect SATA HDD to a mobo w/o SATA port
I have following config
AMD AThlon XP 1800+
MSI KT4 mobo, w/o SATA ports
512 MB ram
Sony DVD rom and Sony CD RW
Sony FDD
a spare Samsung 40 GB IDE HDD in an USB case.
Now my DAD accidently purchased a Seagate 160 GB SATA HDD and the dealer is not taking it back. Now plz help me to connect it to my mobo internally i.e. not via USB port.
If possible I would like to boot from it i.e. win XP on it and use my 40 GB HDD in its USB case which i bought 6 months ago.
PLZ help
ashnik is offline
Old 25-03-2006, 01:41 AM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Just use a SATA PIC card . It might be available in the market. or use a SATA it PATA convertor . thats the best you can do if you want to connect it internally.
This is how a SATA PCI card looks like
If you cant find it in the market try ebay link
Charan is offline
Old 25-03-2006, 01:55 AM   #3 (permalink)
what would be the cost of both options?
ashnik is offline
Old 29-03-2006, 01:40 AM   #4 (permalink)
Check out the price from ur computer dealer... As prices are different in different cities.....
varungupta17 is offline
Old 29-03-2006, 04:03 PM   #5 (permalink)
Default Reply
IF ur not willing to buy the card mentioned .Ask ur dealer to take that SATA disk back and buy something else from that amt u would receive from it.
Dvd writer would be a good choice or a printer
Andyiz is offline
Old 29-03-2006, 05:25 PM   #6 (permalink)
You could buy an external enclosure and use it as an external hard disk.
drvarunmehta is offline
Old 30-03-2006, 09:33 PM   #7 (permalink)
ymhatre's Avatar
charangk THnx for givin info abt such card...
I was not knowing this....
And installing this does we get the same speed wht SATA gives on normal SATA port
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 31-03-2006, 08:52 PM   #8 (permalink)
sorry for the delay and good news guys ! I got a PC order on WITH 120 GB SATA Hdd. but I convinced him to buy 160 GB SATA. So my worries r waved off.
Thanks for ur support
ashnik is offline
