Is the drive displayed under My Computer?
Since you can read and write, your drive happens to be installed on your PC. Check whether the drive appears under device manager. If it does, remove it and restare your PC, then it will get reinstalled and should appear. If this doesnt work, Tell me.
__________________ "Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium (Latest Post : Where does music come from?) Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
Re: DVD writer works with Linux & Win 98 but not with Win XP
Now its working fine!!
I had another CD writer connected to my PC. The CD writer was in master mode and the DVD writer was in slave mode. After I unpluged the CD writer and once I set DVD writer as master I started working fine.
