Old 22-03-2006, 11:29 PM   #1 (permalink)
Default Help in upgrading my 3 year comp
Here are my comp specs:
AMD Athlon(tm) XP 2000+ Thoroughbred Socket A
Motherboard model KM266-8235,
RAM 768 MBytes
GeForce 6200 (AGP)
Now I want to try and be economical or..cheap.. any way you look at it because I don't think I can scrap up enough money for a completely new comp.
So I would like to know what would be the best proccessor and motherboard I can get for under 8000 Rs.
Thanks for any help
roccstar2 is offline
Old 23-03-2006, 12:08 AM   #2 (permalink)
gxsaurav
Posts: n/a
u r short on budget, for 10k, u can get a Athlon64 3000+ with a Asus A8N-VM motherboard, but u will have u leave the AGP card u have
Even if u go for Intel, in which i would prefer the Pentium D 805 ( if available) for a cheap solution... with an intel original motherboard, u will have to again replace the motherboard.
Last option, Athlon64 3000+ with Asus A8V motherboard, that has an AGP slot without onboard gfx,so u can use your existing solution
however.. why do u want a new CPU at all, your current system is good enough for all nongamings things
Old 23-03-2006, 07:23 AM   #3 (permalink)
mav3r1ck's Avatar
what i would suggest is that u sell ur AGP card and with that money along with the money u have already, buy a new AGP card and if possible some more RAM. go for 6600 GT or X800 GTO which should cost u under 10K's. and if u find X800 GTO let me know from where and at exactly how much cost?
cha.
.....i have seen god, he plays as a chelsea striker.....
mav3r1ck is offline
Old 23-03-2006, 10:25 AM   #4 (permalink)
i support mavrick ^^^^^^
thinktwice is offline
