Old 22-03-2006, 10:32 AM   #1 (permalink)
Default DVD Writing takes time
Hi,
I recently bought the LG DVD writer.I tried to write data DVD of about 1.7 GB for testing.I was successfully added the files and clicked burn.However it is taking long time,so I just cancelled the process and tried with just 700 MB and it has written successfully.I noticed that it first caches the file and then writes on to the DVD.
Is there any thing to do avoiding the file caching and write the DVD.
My PC config is as follows
AMD Athlon 64 3200+(939 socket)
Asrock combo-z motherboard
win XP SP2
512 MB DDR(333 Mhz) TwinMos
LG DVD Writer
160Gb hdd(SATA)
DMA enabled for the Device
Thanks
Guhan
guhanath is offline
Old 22-03-2006, 10:16 PM   #2 (permalink)
q3_abhi's Avatar
Every time, all the files are being cached bfore writing ( be it a CD or DVD ).
Caching takes time when there are lots of files .
Try to write the same data with same writer on other computer.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 25-03-2006, 01:11 AM   #3 (permalink)
You cant disable caching completely. Actually it will ensure that your burning process will not fail halfway through. Exactly how much time does it take for you??? Please specify
hsksattish is offline
Old 25-03-2006, 02:42 AM   #4 (permalink)
hmmm......strange...my case is almost opposite...
i was amazed when i wrote 4.15Gb worth of movie files ( Lost Series ..first 12 episodes) on DVD with 6.0X writing speed using Roxio S/W and it burned the whole DVD in 10/12 mins!!!!
what amazed me was that a normal CD when burned at 32X ( 700 MB ) takes atleast 5-7 mins...then how come 4.15 GB in 10 mins!!
and yes i have checke the DVD on DVD player,its working fine !
try burning the disc again ...but before that do a disc defragmentation..it might help. Also which media brand are you using???
grinning_devil is offline
Old 25-03-2006, 11:00 PM   #5 (permalink)
dIgItaL_BrAt's Avatar
@grinning devil:In CD's, 1X is equal to 150 KBps; with DVD, 1X is equal to 1.38 MBps.That's why.
dIgItaL_BrAt is offline
Old 26-03-2006, 01:03 AM   #6 (permalink)
Even the media brand will affect speeds. I hav noticed that while writing into cheaper cds, even though nero reports that it is writing at 40x or something it is actually writing much slower. (Writing at 40x takes same time as 24x.)
Maybe trouble maybe ur media or maybe some firewall running in the background that may slow down the caching process.
Old 26-03-2006, 02:18 AM   #7 (permalink)
deathvirus_me's Avatar
Exactly how long is it taking ???? the buffering time mainly depends on the total no. of file ....
deathvirus_me is offline
Old 26-03-2006, 05:09 AM   #8 (permalink)
dissel's Avatar
In Sony DRU-810 A .....a 4.7 GB Full of Movie/Data File writing at 8.x speed takes 7-9 Minutes with 256 MB ram OS Win XP Pro.
dissel is offline
Old 27-03-2006, 06:55 PM   #9 (permalink)
Default Will Try the possibilities
Hi,
Thanks for all your replies.will try the different possibilities mentione dby u all.
Will get u
guhanath is offline
