Old 21-03-2006, 10:43 PM   #1 (permalink)
Default How to connect two monitor????? HELP PLEASE
I have ASUS Sli Deluxe Mother Board and Asus NVIDIA GeForce 6200 TurboCache. It got a VGA Connect and DVI-D Connector. I bought DVI-D connecter cable for connecting second monitor spending around Rs. 600. Both the Monitor are CRT 17" Samsung. When I connect the one end of the cable to DVI-D (PCI Express Card) and other end to my second monitor I get a message saying NO SIGNAL. I need to connect Dual monitor to my computer.
Not ready to spend on DUAL SLI PCI Express Card (Very Expensive)
PLEASE ANYONE HELP.
WHAT Is different between DVI-I and DVI-D.???
Any ASUS DUAL PCI Express Card available in Market?
MODEL NAME Please
Thank you
stalin
stalin is offline
Old 22-03-2006, 12:02 PM   #2 (permalink)
i think im just tired but i dun think i quite got what u said ..
anyways to ENABLE dual monitor support ull have to do it thru display properties in windows
u cant just plugin the second monitor and expect to have both the screens on
in display properties .. in the last tab ( settings i think )
click on the second monitor it shows u
right click on it and select "active"
then click "extend my windows desktop to this monitor)
make sure this is "NOT" set to default and that ur monitor 1 is default ..
i hope this helps u ..
No Mercy, No Limits.
theraven is offline
