Originally Posted by cooldip10
Hey guys,
I want to connect my laptop to my pc through LAN. I've the wire which is required but still I'm unable to connect them.. Can anyone help????
Hey.....do you Climp the both side of the wire with RJ-45 Sockets.....
Here the cable orientation
http://www.makeitsimple.com/how-to/dyi_crossover.htm
If you do all this......then you need to just assign IP Address of Both PC's Ethernet Cards Properities.....and try to ping each other....and thats all.
Or you need to say more details of your problem.
