Old 19-03-2006, 12:43 AM   #1 (permalink)
Default to all geeks... there is a problem in my IBM laptop...
there is a problem in my IBM laptop model no NQ7 ....n the prob is tht somtimes when there is power cut it hangs n nothing can b done after tht EXCEPT shutting it down!!!!!
it also happens when it is on battery n then power comes back!!!!
this prob occurs ocassionally (2 out of 10 times)
so plz suggest the solution....
is it due to hardware or software or in win XP or it is due to some virus!!!!
or it is a defected piece.....
INTEL IS INSIDE BUT AMD IS EVERYWHERE..
thinktwice is offline
Old 19-03-2006, 12:50 AM   #2 (permalink)
g_goyal2000's Avatar
Probably hardware.
Get it checked.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 19-03-2006, 12:52 AM   #3 (permalink)
Rubik's Uncle!!
Charan's Avatar
I guess its a Driver problem. I had seen some where on the net about similar problem.xp's power managment feature might be the problem nay way try to update the drivers and look for some patches.
Charan is offline
Old 19-03-2006, 06:53 AM   #4 (permalink)
I sometimes would have this problem when I was using DataOne. My laptop would hang when the power went out. I'm guessing it was DataOne causing it because my laptop never gave me any problems if the power went out when I was not using DataOne. If you are using DataOne or a similar service, try and see if you have the same problem without the service on. Just stop using the internet and turn off power to the laptop and see if it still locks up.
Nemesis is offline
Old 19-03-2006, 10:22 AM   #5 (permalink)
Default hi
wht is dataone???
Old 19-03-2006, 11:12 AM   #6 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Dataone is BSNL's broadband service.And the problem can be due to your power managment settings.Get your windows updated by the latest AutoPatcher Xp.
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad.. ;)
kaustav_geek is offline
