Old 19-03-2006, 12:22 AM   #1 (permalink)
Default How much overall PC performance diff by add 512 MB ram
I have
Amd Athlon XP 1800+
MSI KT4 mobo
512 MB ram DDR 333
5200/128 AGP 8x
HDD 160 GB Barracuda
Sony DVD rom
Sony cd writer
Dlink Lan card
Now If I add 512 MB ram by how much %ge will the performance increase? The PC is mainly use for gaming, photoshop and movies.
I am going to buy a 6600 GT/128 card for a frnd in next week, maybe friday. I will buy the ram for myself at that time only.
Plz, reply.
thank you!!
nikdesign4u is offline
Old 19-03-2006, 12:45 AM   #2 (permalink)
g_goyal2000's Avatar
Firstly, don't buy 6600 GT/128 card.
Nvidia has released GeForce 7800 GS graphics cards for AGP-based systems.
http://www.nvidia.co.in/object/IO_29186.html
Try to go for it.
Yes, u will get a performance boost but not that much by adding more RAM. But while buying RAM, buy the identical RAM which u have.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 19-03-2006, 02:31 AM   #3 (permalink)
Default hi
it helps when u run both the rams in dual channel mode!!!
then u get the double speed of the single ram...note that both the rams sud b identical!!!
INTEL IS INSIDE BUT AMD IS EVERYWHERE..
thinktwice is offline
Old 19-03-2006, 07:43 AM   #4 (permalink)
mav3r1ck's Avatar
@nikdesign4u,
if u buy additional 512 MB RAM, yes there will definitely be a performance increase as far as gaming and using photoshop is concerned, i.e quick loading and rendering time. if ur mobo has a dual channel option try enabling it by buying a RAM similar to what u have and inserting it in the correct DIMM of ur mobo.
i suggest u go for the 6600 GT, way economical as compared to 7800 GS, and the performance boost for gaming will be HUGE!!!!!!!!! since u have a 5200 the difference in gaming will be like DAY and NIGHT!!!!!!!!
cha.
.....i have seen god, he plays as a chelsea striker.....
mav3r1ck is offline
Old 19-03-2006, 02:02 PM   #5 (permalink)
Well U can buy 6600 GT/128 card. It is good.
But if u can afford, then buy GeForce 7800 GS/256MB graphics card.
Old 19-03-2006, 04:09 PM   #6 (permalink)
nishant_nms's Avatar
What will be cost of 6600gt and 7800gs for AGP
nishant_nms is offline
Old 19-03-2006, 09:33 PM   #7 (permalink)
q3_abhi's Avatar
RAM will definitly boost ur performance and it is a gud future investment.
6600GT - around 7500/-
7800GT- around 32,000/-
I think 6600GT 128 MB will b a gud option.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 20-03-2006, 12:59 AM   #8 (permalink)
Where did u get those prices from??
Are they for real or u'r just guessing???
Old 20-03-2006, 08:06 AM   #9 (permalink)
q3_abhi's Avatar
They are the approximate ones coz it differs from city to city but these are ones given in DIGIT mag.
q3_abhi is offline
Old 20-03-2006, 03:01 PM   #10 (permalink)
@q3abhi:
U quoted price for 7800GT which is for PCIX-16 slot. It also has onboard 512 MB RAM.
7800GS is an agp card with 256MB RAM.
It will definetly be cheaper than 7800GT.
Old 20-03-2006, 03:16 PM   #11 (permalink)
How much is the cost of Geforce 6800
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 20-03-2006, 07:23 PM   #12 (permalink)
As I have mentioned earlier, My frnd is buying 6600GT/128, I can't convince to buy any other card.
Thanks guys for quick reply.
BTW should I go for 1GB or not??
Old 21-03-2006, 12:19 AM   #13 (permalink)
::vicky::'s Avatar
yes more the ram u have more secure is ur future
::vicky:: is offline
Old 21-03-2006, 12:19 AM   #14 (permalink)
::vicky::'s Avatar
Old 21-03-2006, 12:44 AM   #15 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Yes 1GB is wat u shud go for as system performance will improve especially if u upgarde to vista later.
Ankur Gupta is offline
