Old 17-03-2006, 11:44 PM   #1 (permalink)
Default which is more reliable???? ASUS or MSI...
INTEL IS INSIDE BUT AMD IS EVERYWHERE..
thinktwice is offline
Old 18-03-2006, 12:02 AM   #2 (permalink)
yogi7272's Avatar
ASUS ANYDAY ...
yogi7272 is offline
Old 18-03-2006, 05:16 PM   #3 (permalink)
mobilegeek's Avatar
I prefer ASUS ..
mobilegeek is offline
Old 18-03-2006, 06:05 PM   #4 (permalink)
Both are very reliable, but Asus is just a little better.
drvarunmehta is offline
Old 18-03-2006, 06:12 PM   #5 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
Thats true .. ASUS has a little edge .. I am also using ASUS K8N
rollcage is offline
Old 18-03-2006, 06:50 PM   #6 (permalink)
Dreaming Future
kin.vachhani's Avatar
hey man both r doing good in the market.....
well it all depends what feature u want from the mother like overclocking...dual processor support...even price . If u have less budget go for msi otherwise go for asus..they r really good ones...personaly i am using msi rs480 m2il motherboard for athlon 3000+.
World without Computer is like a man without Brain.....
kin.vachhani is offline
Old 18-03-2006, 07:16 PM   #7 (permalink)
Your Maker.
MysticHalo's Avatar
I prefer ASUS mothrboards....but MSI is flooding indian markets..check out ebay.in if u dont believe me !!!
BTW, arent intel mobo's good......for intle processors?
“Talent is a flame, but genius is a fire.”
MysticHalo is offline
Old 18-03-2006, 07:56 PM   #8 (permalink)
I like MSI coz they are cheaper and I am using MSI KT4 mobo from last 3 yrs. Since I assemble and sell PCs, I have done sssso much R&D on this mobo. Atleast 10-15 CPU chips, many memeory sticks of different brands, many SMPSes, atleast 50 HDDs and other IDE devices eyc. Still going rock solid. Also u get higher features on MSI at lower cost.
eg. AMD 939cpu mobo
MSI K8NGM2-L mobo with onboard nVidia 6100 GPU has high definition 7.1 audio chip while the corresponding ASUS mobo A8N-VM has High definition 5.1 sound chip. Also the most important feature is that u can just buy a TV-out module from MSI and enjoy all those DIVx movies on ur TV. This feature is not in ASUS A8N-VM. More over this MSI mobo is 1K cheaper than ASUS A8N-VM.
Also I really like the utilities and the manual of MSI. They are really useful and many. The maual is more explaining than that of ASUS.
I have used and sold both mobos, but I like MSI K8NGM2 more. There are some customers who ask for ASUS only otherwise i would have sold them MSI only.
I have many times seen a query on this forum about "How to check the actual network speed of my MTNL/BSNL broadband or Cablenet?". This is where MSI ISpeeder utility helps. I have a 64kbps cablenet account. i always monitor iSpeeder and if the average speed goes below 64kbps i just call the cablewalla and he fixes it. This happens atleast once in a week. THis way I get max out of them. Not only this, but when I use DC++ or windows n/w for file sharing, where I get speed in 7-8 MBps, i can see the data tranfer rate in both, kbps and KBps. I really like this utility. I have tried many 3rd party utilities but, iSpeeder always gives correct value. The iSpeeder is so accurate because it directly monitors the motherboard chip where most 3rd party utils use windows. U don't get ne such utility with ASUS.
In ASUS mobos, if ur using the PC and for some reason there is a power failure or blackout and the PC gets switched off, then next time when the power comes back the PC starts automatically w/o pressing the power switch on the cabinate. This is something I don't like. This will continue till the time u do not properly shut down the PC.
An incident happened with me, I don't really know whether this has to do nething with the quality of MSI mobo, is like following.
I have a friend in same soc with ASUS mobo PC. Me and he get the lan wires for cablenet from the same switch, or hub. We both had similar D-Linc DFE-538TX lan cards on PCI slots. In last July, both PCs were ON and a stong lighting happened. Intantly, both PCs went OFF. But the next minute, I switched ON mine by pressing power button on cabinet and it started and everything was normal. But friends PC started too but his lan card was gone. I took his card to the service center, but they said that since the card was damaged by lighting i.e. surge in line, no warranty was applicable. So he had to buy a new one. Experts, PLZ explain this
BTW there is no difference in after sale services of both companies. They are really good.
WOW,I just saw the preview of this post, should i post this in REVIEW..... section?
ashnik is offline
Old 18-03-2006, 08:33 PM   #9 (permalink)
bang bang!
Chirag's Avatar
Asus for me.
Chirag is offline
Old 18-03-2006, 09:32 PM   #10 (permalink)
Default hi
eg. AMD 939cpu mobo
thanks a lot ASHNIK!!!!
if suppose u hav to choose one from these two
ASUS A8N 32 SLI deluxe or MSI K8N diamond plus
which one u will choose ....think twice as both of them r full of features
Old 18-03-2006, 09:55 PM   #11 (permalink)
ymhatre's Avatar
HEY MAN
Heres one trick....
CLose ur EYES ....
N THen SELECT ASUS.....
ASUS : - BLINDLY ACCEPTED.......
Trust Me
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 18-03-2006, 10:28 PM   #12 (permalink)
Default Re: hi
[/quote]
wowow, will take atleast a day for through comparison !
As for now, i will buy MSI if it is for me, i mean w/o if i have to choose comparing.
R U GONNA BUY ONE OF THEM OR JUST WANNA BUG ME
coz i will waste many hours on it and this comparison won't be useful for me. I am never gonna buy ne SLI mobo nor I suggest one.
ashnik is offline
Old 18-03-2006, 11:30 PM   #13 (permalink)
Default Re: hi
coz i will waste many hours on it and this comparison won't be useful for me. I am never gonna buy ne SLI mobo nor I suggest one.[/quote]
if suppose i wanna buy diamond plus then is it available in india!!!!
Old 19-03-2006, 01:13 AM   #14 (permalink)
g_goyal2000's Avatar
Default Re: hi
Yes it is.
In Delhi, in Nehru Place.
In Mumbai, Lamington Road.
Rest, I don't know.
g_goyal2000 is offline
Old 19-03-2006, 02:04 AM   #15 (permalink)
Default Re: hi
Yes it is.
Rest, I don't know.
n for how many bucks???
Old 19-03-2006, 02:03 PM   #16 (permalink)
Will tell u on either tuesday or wednesday.
Will goto Nehru Place then.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
Old 19-03-2006, 03:29 PM   #17 (permalink)
I checked the site of MSI feature wise I think MSI is ahead of ASUS.
Is it true that MSI is having more features when compare to ASUS?if yes what r those??
Guide me..
Curious to know abt this..
nawaz123 is offline
Old 19-03-2006, 10:06 PM   #18 (permalink)
The pWnster
Vyasram's Avatar
asus rules
Asus>MSI>Gigabyte
Sigs suck
Vyasram is offline
Old 19-03-2006, 10:26 PM   #19 (permalink)
ASUS anyday
Top 10
Toocool is offline
Old 19-03-2006, 11:21 PM   #20 (permalink)
dIgItaL_BrAt's Avatar
Go for ASUS.
dIgItaL_BrAt is offline
Old 19-03-2006, 11:33 PM   #21 (permalink)
Becos everybody reads digit.
Digit is saying so go for ASUS.
Right DUDES..
I will go for MSI. I will find latest features with this mobo.. from MSI.
Performance wise thos people know who r having it.
I just upgrading from Intel mobo to MSI mobo..
nawaz123 is offline
Old 20-03-2006, 08:05 AM   #22 (permalink)
The pWnster
Vyasram's Avatar
no, i say asus rules due to my personal experiences. MSI doesn't hav the support that asus gave me. BTW digit doesn't say "asus rulez" all the time.
Sigs suck
Vyasram is offline
Old 21-03-2006, 12:54 AM   #23 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Well i just bought MSI mobo and it simply rocks!!!!
no guesses who from the above guyz helped me do so!!!!!
Ankur Gupta is offline
Old 21-03-2006, 02:43 AM   #24 (permalink)
Learner
Kniwor's Avatar
I say is a stupid question... there is no point comparing the 2....
just ask which 2 motherboards to compare....
But if i were to give an answer.... it will be MSI...
not that asus makes bad motherboards or anything... but for the same price, same chipst... same socket...
an MSI motherboard will usually have more features.... both are stable, both are durable... both are nice....
but there can be specific models by both manufacturers that can be good or bad....
Kniwor is offline
Old 21-03-2006, 10:35 AM   #25 (permalink)
Jai Suresh
lywyre's Avatar
ok guyz, when u say ASUS is better than MSI, just give enough reasons to justify!
lywyre is offline
Old 21-03-2006, 10:59 AM   #26 (permalink)
yogi7272's Avatar
Just consider intel 975x chipset ... out of gigabyte , asus and msi .. the asus board is best performing and most stable under overclocking ...
also for nvidia 32x sli chipset for amd .. asus one performs bit better than msi diamond plus ... only advantage msi has in both these chipset boards are they have onboard creative live 24 bit ...sound solutions .. not to say that both these msi boards are bad .. but asus is just bit better .. not to forget nvidia 32x sli chipset intel edition board of asus which is one of the best boards to get for intel processors ..
I would say msi ones are mostly better than gigabyte boards ...
yogi7272 is offline
Old 23-03-2006, 02:05 AM   #27 (permalink)
thanks ankur
guys when i bought my MSI KT4 mobo,digit had given it THE BEST in comparison test.
Just imagine guys in 2003 I had bluetooth and IR onboard, a special bracket with 4 bicolour LEDs to idicate the fault in system..
I am proud that i made a wise decision..
BTW MSI support is as good as ASUS.
ashnik is offline
