i doubt it even has an AGP slot leave alone a PCI. dude i suggest u upgrade ur PC if u wanna play the latest games. i hope all ur queries are answered
i said pci slot and not a pci e
all mobos have pci slots. and there r pci gpu still available on ebay.in
there's no 7300 rpm HDD, it's always 7200 rpm HDD. don't waste money on buying a new HDD. get urself a new mobo and a processor. the reasons being u have an 810e so i think either u have an intel P-III processor or a celeron one. on the question of whether ur 810e mobo supporting the large sized HDD, even if it did there won't be any performance boost in the way u transfer ur data, since ur CPU and MOBO are the bottlenecks. next, if u are buying a PCI-E mobo + processor, why do u want to opt for an PATA HDD. go for a SATA HDD. yes your existing PATA HDD will work on the new mobo provided it has an IDE interface connector. It (the new mobo) certainly would be having an IDE interface so that u can connect ur CD/DVD drives, u would have to unplug the CD/DVD drives and then connect ur existing PATA drives to these and then transfer the data to the SATA drives. NO a SATA drive will never work on an IDE interface. the cables are way too different. check out http://deltapage.com/ for the HDD, DVD/CD ROM prices. s
7300 was a typo. its 7200
thanks for ur reply as i was thinking the same that an ide hdd wont work well with a sata mobo and cause bottlenecks
but i dont want any performance upgrades right now. if it works well like my 7200 rpm drive then well and good.
will a new sata hdd work on an ide only supporting 810e mobo?
that way i can buya sata hdd. and use it on new comp when it comes
actually the reason is that i have 6000/- for upgarde and even if i sell my 8mnths old liteon cd writer for some 1200
i will have 7200/-
and i want to buy a 160 gb hdd, dvdwriter(massive backups) and a tv tuner
so cud u help me as a tv tuner recording will use lots of space on my hdd.
and right now of the 5 partiions (2 hdds=
sgt 40 gb 7200rm =2 partitions and
WD 5400 20 gb hdd =3 partions)
freespace
c
windows xp)= 3.12 off 8.93(on SGT)
d
temp storage for net dLs)=2.74 off 2.92(on WD)
e
games, warez+songs)= 2.36 off 28.3(on SGT)
f
complete e: backup-games)326 mb off 9.76 gb(on WD)
g
mandriva linux)= no usable in windows
much much space will a tv recordig of 30 mins take in 1024*768 reso?
i thnik a dvdwriter and a tv tuner will be better
