Old 15-03-2006, 09:21 AM   #1 (permalink)
tiblu's Avatar
Default Cheapest SLI Setup
Hey guys please suggest me compatible good SLI rig which costs minimum. Which processor, mobo, Graphic cards(SLI) and memory should i go for? I dont want any HI-FI suggestion please, it should not cost a Bomb for me. Thanks
tiblu is offline
Old 16-03-2006, 12:10 PM   #2 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
To tiblu:
WELL SLI SYSTEMS DO COST A BOMB!!!
Cheapest SLI setup can include two XFX 6600 GT(Rs 8k x 2) chipsets but that won't give any significant performance boost.In fact a 6600 GS single-handedly beats that setup!!
I suggest you go for two XFX 6800 GS(Rs 14k x 2) in SLI on an ASUS A8N-SLI(Rs 9k).Go for an AMD 3500+(Rs 10.5k) with 512x2 DDR 400 Hynix Ram(Rs 4.5k).
This is a good configuration which you can really CALL SLI!!
-Kaustav
kaustav_geek is offline
