Old 10-03-2006, 12:29 AM   #1 (permalink)
Default Want: VHS to CD. Means: Suggest!!
Hi guys, i have a video camera recording to VHS, you know, that big tape thingy, which of course i outdated, but i have some really important things recorded on it, but lately it has developed fungi and i want it converted into cd. Please express your honourable suggestions and stuff it into my grey matter.
Dumbledore is offline
Old 10-03-2006, 01:16 AM   #2 (permalink)
well, u will need a capture card in ur PC
A good TV tuner card will also work but with lesser quality
ashnik is offline
Old 10-03-2006, 07:56 PM   #3 (permalink)
digiFriend's Avatar
Compro VideoMate TVPVR (M100) bestbuy from december DIGIT or november.
COMPRO VideoMate TV PVR features with high quality encoding ADC and tuner, which provides state-of-the-art performance on picture quality.
With the COMPOSITE and S-Video input/output connectors, all home A/V appliances can be easily hooked to VideoMate TV PVR, and even transform your old VHS tapes into digital formats. (higher priority)
FM version also provide FM radio listening and recording.
This tv card has very good result, and available at price 2250 RS on SIFY shopping. make sure you have ntfs partition which allows to save large file over 4 gb. or if you have FAT32 , and windows XP on it, most video editting software automatically split large file. But be sure to enable splitting of large file option in video editting software. i have used Ulead video studio with very good result.
digiFriend is offline
Old 11-03-2006, 03:25 AM   #4 (permalink)
abhishek_sharma's Avatar
yup any good v tuner card will do...i have used compro videomate tv tuner card's composite video in jack to transfer videos frm vhs to cds
but the fungi thing is a cause of concern, try get it cleaned by ppl who professionally convert vhs tapes to cds/dvds. even when i was conevrting my tapes the same probs of bad footage occurred in places where the tape was affected by fungus...and since its physical damage, no matter how good a card u use, u cant rectify it, w/o actually cleaning the tapes.
conversion of raw avi to cd can be done by ulead vid studio n u'll get good results
abhishek_sharma is offline
Old 12-03-2006, 10:46 PM   #5 (permalink)
thank you for your honourable replies, i will certainly try it and get my humble reply back to you
Old 13-03-2006, 05:21 AM   #6 (permalink)
Resident Weapons Expert
zombie's Avatar
Dude, if you have a camcorder, then this is the way to go. No need to opt for any video capture card. Check it out. Connecting Video Devices to Use DV Pass-Through.
zombie is offline
