Old 09-03-2006, 10:53 PM   #1 (permalink)
ymhatre's Avatar
Default Connecting ASUS P5rd1 - VM to TV - out ?????
Guys i hav P5RD1 - Vm mobo. It has TV- out connector on board.
So can u please tell me how would i connect it to Tv
Do i need any cables or card plz
ANswer with details!!!!!!!!!!!
THNX
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 10-03-2006, 01:19 AM   #2 (permalink)
just get the tvout cable from an electronics shop, rs. 50 max. But first carefully see the connector on ur TV i.e. AV in.
ashnik is offline
Old 10-03-2006, 01:53 AM   #3 (permalink)
::vicky::'s Avatar
ya cable is pretty cheap u wont have problem buying that cable
::vicky:: is offline
Old 10-03-2006, 07:07 AM   #4 (permalink)
ymhatre's Avatar
BUt man the port to connect it to motherboard is not on rear pannel nor on front pannel its inside board just above pci express x16 slot. The port of slot is lke this
[:.:] <------ LIKE THIS (JUST 5 DOTS)
HENCE NOW HOW TO CONNECT.
Do i get specifiic cable for such slot. If yes then whts the name of chord, where can i get it(i stay in mumbai)
http://www.asus.com/products4.aspx?l...70&modelmenu=1
Here u can see the view of the board. Just enlarge the view and there u will see that there is a rectangular socket consisting of 5 - pins just above pci express slot and adjajent to lan - usb rear pannel connector .
It is mentioned on the board diagram, tht it is TV-OUT. but how to connect to tv is not ???
Plz help me...
ymhatre is offline
Old 10-03-2006, 10:12 PM   #5 (permalink)
ymhatre's Avatar
PLZ reply man
WHERE are all digits hero brad, vijay etc where r u guys.....
DusT = ME
ymhatre is offline
Old 10-03-2006, 10:13 PM   #6 (permalink)
ymhatre's Avatar
PLZ reply man
WHERE are all digits hero.
DusT = ME
ymhatre is offline
Old 13-03-2006, 01:41 AM   #7 (permalink)
I have just now d/l and read the manual. i believe u will have to contact Asus india and ask them for the special module to connect TV out pins on mobo.
http://in.asus.com/aboutasus.aspx?show=3
Headoffice : call here first
ASUSTeK Computer Inc.
101-108 Bonanza, A Wing,
1st Floor, Sahar Plaza Complex,
M. V. Road, Andheri (East),
Mumbai 400 059
Phone: 022 40058905 / 40058898
Fax: 022 40058916
E-Mail: info_india@asus.com.tw
Mumbai dealer
Digicomp Systems Pvt. Ltd
18/20, Wimbridge building,
Sleater Road, Near Shamrao Vithal Bank,
Grant road (west),
Mumbai 4000 007.
022-56764313 // 23852501
022-56764188 // 23822601
Mr.Girdhar / Yogesh / Milind / Srinivas
ashnik is offline
Old 13-03-2006, 07:57 AM   #8 (permalink)
ymhatre's Avatar
THnx Ashnik For helping me..
I will just call them and check out...
Will post abt this if any difficulty..
Thnx
DusT = ME
ymhatre is offline
