Old 08-03-2006, 03:45 AM   #1 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Default DDR prices to go up or down?
Hey I will be upgrading my pc in 3 to 4 months now. From PIII to AMD 64.
So if DDR's pricesare expected to go up,then I won't wait for that to happen but simply buy the ram and keep it .
DDR is supercheap now , Have a look :Ebay - This is ddr 512mb 400Mhz, 3 years warranty - for 2100 (including shipping) . Ise sasta aur aacha aur kahan??
Wot say? prices going up or down??
chesss is offline
Old 08-03-2006, 08:25 AM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
there might be a slight hike in all comp peripherals post the budget
i.e. frm april onwards
vijay_7287 is offline
Old 08-03-2006, 12:24 PM   #3 (permalink)
chesss's Avatar
Slight hike. hmmm what about the regular price hike as DDR becomes more mainstream and SDram goes extinct.
chesss is offline
Old 08-03-2006, 05:29 PM   #4 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Vijay is ri8.....
After the Budget the prices will be up even if it becomes mainstream.....so if u plan to buy after 4 monthsu can buy now but hen u will not be using it and then also the warranty period will be used up.. so think before u buy.........if few thousands doesnt matter then better wait...
wizrulz is offline
Old 08-03-2006, 06:03 PM   #5 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
DDR is the mainstream now
and the prices have been coming down all the while
just tht the budget had some small taxes on it
even then the minor hike is worth takin , given tht u have the warranty thingy at stake
when buyin a new system keep it new!!!
