Old 07-03-2006, 08:04 PM   #1 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Default I am in a fix pls help........
Well here is my problem......
I am upgrading in a week or so and i have abt 18K cash in my pocket.
i want to invest in a motherboard which is dual-core capable but i donot plan to buy a dual-core now due to high prices.
Now i donot plan to invest in a graphix card now so lookin for onboard graphix on mobo but it shud have a PCI-e slot.
i have searched various threads in the forum and found ASUS A8N-E a gud mobo but alas it has no onboard graphix.Now ASUS A8N-VM seems like a gud mobo but i want a mobo with gud overclockin facilities as well so does it fullfill my requirement
So which mobo shud i go for... donot want SLI or crossfire support...which is the best?heard MSI NEO4 PLATINUM(is tht its name ) is also gud.
And now abt the procy.
As these mobos support 939 pin procesors the cheapest option available in market in AMD 3000+ for 5.5K.
So if i invest in tht mobo i will have to ditch it next year losin my 5.5K bucks
So if i invest in 3500+ do u think then i shud go in for dual-core next yr.means is there much difference b/w 3500+ and 3800+X2???
I will get abt 35-40K next year so i dont want to waste my investment now.will buy graphix card next year.
pls advise me on mobo and procy
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 07-03-2006, 10:49 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
depends on wat ur needs are
if u r some kinda gamer
maybe ur hunger for higher end processors is understandable
and ur query is real confusin
frm wat i understand
u wanna buy a Proc & Mobo now for 18k
so i think u can still go for a 3500+ and a Asus a8n-vm-csm
vijay_7287 is offline
Old 07-03-2006, 11:00 PM   #3 (permalink)
Well i am not a gamer but want my PC to be vista compatible.
my need for higher end processors is only for future proofing coz i will not upgarde for 4 years after i upgrade next year.
I want proc+mobo+ram for 18K now.
Old 07-03-2006, 11:25 PM   #4 (permalink)
lavan_joy's Avatar
Better wait for the VISTA realease and finalise the configuration.
LAZINESS IS THE ENEMEY OF SUCCESS
lavan_joy is offline
Old 08-03-2006, 12:27 AM   #5 (permalink)
abhishek_sharma's Avatar
i dont think the msi neo4 platinum has onboard gfx.
u can go in for msi K8NGM2 series boards...they have inbuilt integrated 6100/6150 gpu and will work well with vista also.
abhishek_sharma is offline
Old 08-03-2006, 12:00 PM   #6 (permalink)
So is MSI K8NGM2-FID a better mobo than ASUS A8N-VM???
and does anyone know the cost of the MSI mobo???
Old 08-03-2006, 03:16 PM   #7 (permalink)
U've hurt me !!
ashnik is offline
