Originally Posted by kaustav_geek
To wizrulz:
Try a firmware update from your CD-writer's vendor's site. If possible,try reinstalling your drive. Check it in any other system if you can. I'll check on for more info and tell you. Till that time you try the above and inform on the forum of the outcome.
Atlast some1 is helping....thanks buddy....
tried updating firmware, but no help.......also reinstalled the drive.......actually no drivers seen while again installing the drive...... :roll:
Win xp uses its drivers i guess........please do post in if u find the solution,,,,,,,,
