sorry guys i confused pcie with pci-x...
btw @ ::vicky::
A connection between a PCIe device and the system is known as a "link" and this link is built around a dedicated, bi-directional, serial (1-bit), point-to-point connection known as a "lane". A lane is capable of simultaneously transferring 250 MB/s of data in each direction. A link can use more than one lane at a time but all links compliant with the PCIe specification must minimally support single-lane connections, referred to as "x1" (pronounced "by-one") links.
For higher potential bandwidth, PCIe devices and systems can optionally support links using multiple simultaneous lanes – for example, a "x16" link uses 16 lanes. To support extra lanes, a PCIe card and slot must be designed to accommodate the extra electrical lines required (2 lines per lane). Card and slot types exist for x1, x4, x8, and x16 links
however, these are down plugging compatible...i.e. if u can add a x8 card to a x16 slot but a x16 card will not fit into a x1,x4,x8 slot...
that is actually clear frm the images posted earlier.
