HELP ME no beep sound moniter does'nt start new pc
i bought intel 865 moth and celeron d processor. when i tried to run it no beep sound comes from motherboard ,nor moniter start but fan is running ,light is comning to motheborad it beeps when i remove REM, HELP ME
harddisk lights are coming , but nothing comes in moniter, it only blinks,
computer doesnt boot up, no beep sound is coming , i tried to run motherbord with minimum component with RAM , PROCSSER THEN ALSO NOTHING HAPPENS HELP
moniter cable is properly atteched i have check it many times , processer fan is running, power supply fan is also running, power LED lights r coming, hardik lights r coming,to me it sems that some capcitor of motherbord may be dead.it has inbuilt speaker if no cable is atteched then also one beep should be there as it normally happens when computer starts.
SMPS IS OK BECAUSE I RUN MY OLD COMPUTER WITH THIS SMPS AS FAR RAM IS CONCERNED IT IS PROPERLY INSERTED BECAUSE IT STARTS BEEPS UP THE MOMENT I REMOVED OR IMPRORPELY INSERTED.
