Old 03-03-2006, 06:48 PM   #1 (permalink)
Your Maker.
MysticHalo's Avatar
Default Which MB is better?
I wanna know which of these 2 MB's would be better-:
http://www.msi.com.tw/program/produc...il.php?UID=697
http://in.asus.com/products4.aspx?mo...3&l2=15&l3=236
Or any other MB u can suggest??? Should be-:
>>dual core processor compilant
>>AMD socket 939
>>Support ATi crossfire
“Talent is a flame, but genius is a fire.”
MysticHalo is offline
Old 03-03-2006, 07:22 PM   #2 (permalink)
The latest Crossfire chipset for AMD has just been released. I suggest you wait for that rather than buying a mobo based on ATI Radeon Xpress 200 CrossFire (RD480) Chipset.
Check out the review here.
drvarunmehta is offline
Old 04-03-2006, 10:03 AM   #3 (permalink)
Your Maker.
MysticHalo's Avatar
Thanks a lot, man !!!
