Old 02-03-2006, 06:57 PM   #1 (permalink)
sandeepthapa31's Avatar
Default Driver & CD burner software for Samsung CD writer
Dear All,
I have this Samsung CD writer bought on 2001. Can anybody tell me where to get its driver from the net and which CD burner should I get. Is these software available on the net. Help???
sandeepthapa31 is offline
Old 02-03-2006, 10:23 PM   #2 (permalink)
The pWnster
Vyasram's Avatar
Check the samsung webste for support and drivers . you must goo for nero or easy mc if you want a decent soln their trial versions are available on net
Sigs suck
Vyasram is offline
Old 02-03-2006, 10:47 PM   #3 (permalink)
Shock_the_Rock
Posts: n/a
Default Hey DUDE !
get drivers from www.samsung.com/drivers, nero is gre8n also try cyberlink dvd .
Old 03-03-2006, 02:18 AM   #4 (permalink)
model number of the drive...
have a look at it frm device manager...
and then locate the driver frm the above site...!
grinning_devil is offline
Old 03-03-2006, 06:34 AM   #5 (permalink)
Default Re: Hey DUDE !
Why do u spam the forum dude???the link u gave is not found.Chk and provide it and dont give a bounced link.....
And i think is that u no need of drive's just plug it windows will do it automatically....And for buring software go with chkt in
 www.nero.com
devarajan is offline
Old 03-03-2006, 10:02 AM   #6 (permalink)
Default not satisfied with the site
Hay dude,
I check this site for driver. I am not able to log on to it, some problem with the site boss. Still need some sites from where i can down load this driver.
Old 03-03-2006, 01:57 PM   #7 (permalink)
Chk in:
 http://www.opendrivers.com/categorycompany/15/1362/cd-rom-samsung-free-driver-download.html
www.totallydrivers.com/drivers/ download-driver.asp?driver=30 - 19k
Old 03-03-2006, 02:18 PM   #8 (permalink)
Try at http://www.driverguide.com/ - very good repository of drivers...
For CD burning software, you can also try freeware alternatives such as CD Burner XP Pro and Deep Burner...
Arun
sakumar79 is offline
Old 04-03-2006, 06:59 AM   #9 (permalink)
@Shock_the_Rock: Please check links before posting them here. The link you gave does not work and returns a Page Not Found error from Samsung.
Nemesis is offline
