Old 02-03-2006, 01:57 AM   #1 (permalink)
sujeet2555's Avatar
Default vibrating fan
i have window-xp pro.whwnever i start my pc my system fan vibrates violently.as i open my account and comes to my desktop.the vibration slowly slowly reduces and goes normal.why is it happening,is there any solution?
s.k.
sujeet2555 is offline
Old 02-03-2006, 02:01 AM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
What is your system configuration? P4 prescott series PC's have this kind of problem. My configuration is P4 520 with 915GAV Mobo . I have the same problem.
Charan is offline
Old 02-03-2006, 02:04 AM   #3 (permalink)
sujeet2555's Avatar
i have p4 ,845gl with mx card .it was fine until my cmos battery starts showing the signs of .however.the battery is still running.
s.k.
Old 02-03-2006, 04:36 AM   #4 (permalink)
its normal..nothing to worry abt...
at the start the fan is rotating at max speed,and later on after detecting the CPU temp it slows down...it happens to me sometimes too...
grinning_devil is offline
Old 02-03-2006, 01:57 PM   #5 (permalink)
sujeet2555's Avatar
but it was running good with no vibration when i installed the system fam (not cpu fan).
s.k.
Old 02-03-2006, 06:13 PM   #6 (permalink)
Shock_the_Rock
Posts: n/a
Default Re: vibrating fan
Hmmmm.. try speedfan from www.majorgeek.com or google search.
Old 02-03-2006, 10:18 PM   #7 (permalink)
The pWnster
Vyasram's Avatar
is it making that screeching noise ,
if so look for tangled wires or have it serviced
If ur experienced in hardware, check out what's making the noise by running the pc with the cab open
Sigs suck
Vyasram is offline
Old 02-03-2006, 11:28 PM   #8 (permalink)
sujeet2555's Avatar
if it was any hardware problem,then why it is normal when i open any account.one more thing,i noticed that
*vibrating fan-less air
*normal fan-more air as compared
s.k.
Old 03-03-2006, 02:04 AM   #9 (permalink)
>> try changing the power cable connected t fan
>> try running the same fan in some other PC
Old 03-03-2006, 06:53 AM   #10 (permalink)
Dude When u boot a pc initilally it loads all the file and it result in giving a heavy load to the processor and when finish's loading the load come down.so the fan work's according to it and make a cool the processor.so no way to worry....Normally these happen's when u play game.Even i have faced these problem......And one more thing some time ur surrounding temp also play's a important role........
devarajan is offline
Old 03-03-2006, 02:48 PM   #11 (permalink)
@devarajan
read the firstr post more CLOSELY...
and u'll realise that its not a CPU fan but instead a system fan...
Old 04-03-2006, 12:00 AM   #12 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
I also ahev problem with one of the fan...when i start playing games its start very fats and vibrates(i guess) and makes noise, when i open the cabinet its stops....any solution???
wizrulz is offline
Old 04-03-2006, 11:02 PM   #13 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Hello guys (and girls) i need solution to my problem and asking in this thread as it dealing with fan.....i dunno which fabn is giving noise......so please do help me out :roll:
wizrulz is offline
Old 04-03-2006, 11:42 PM   #14 (permalink)
bang bang!
Chirag's Avatar
i had the same prob with my fan (smps one). I opened my cabby, cleaned the fan and voila it was running as a new one.
Chirag is offline
Old 06-03-2006, 10:51 PM   #15 (permalink)
In case of Mobos like A8N-E and Cool&Quiet is enabled., the fans,not only CPU, Chipset and even one Chasis fan (if it is connected to the proper slot), runs at maximum speed only during boot up and then slows down based on the temperature. Ony when resource hungry applications are run and the system heats up, the fans speed up.
But of course, this is not for Intel.
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 06-03-2006, 11:31 PM   #16 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Mine is amd 64 bit based PC, so can anyone point out the problem and solution???
wizrulz is offline
Old 07-03-2006, 03:42 AM   #17 (permalink)
mabe try out the power settings in ur BIOS .... i think modifeing them might help...
Rasper is offline
Old 07-03-2006, 07:49 PM   #18 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Can any1 help me out with BIOS setting......i will not like to play with it
wizrulz is offline
