Old 28-02-2006, 10:28 PM   #1 (permalink)
ymhatre's Avatar
Default UPGRADE NEEDED........... BUt WHAT??????
HI Gus
I have Pentium 4 2.4Gz (478 pins)
Intel original mother board 845Gb ( Agp uptill 4X)
768mb ram ( 512 + 256)
40 GB 5400 rpm HDD
Geforce fx 5200 256 mb graphics card ( 8x but working at 4x cuz of mobo)
I need performance from this configuration
Like I enjoy playing games like COD2, NFSMW, POPT2T etc
but play them at low special effects
Even transfering Data frm one partition to other takes more time even on fresh installed OS.
i think 768 is enough ram
even 2.4 is normal
so Wht shld i upgrade
[/b]Hav a budget of 8K - 10K
PLz tell ur opinion
THNX.........
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 28-02-2006, 11:32 PM   #2 (permalink)
GeekyBoy's Avatar
You Should Consider Upgrading your motherboard.If you do not want to upgrade your processor,then go for the AsRock P4 Dual 915-GL.Although the chipset of the motherboard is 915GL,it supports socket 478 processors like the Pentium 4 2.4 Ghz.Also,the motherboard has got both AGP 8x and PCI-E slots.Its a steal at Rs 3900.
Upgrade your hard disk.That might be the sole reason why data transfer speeds are not up to the mark.Buy a Samsung or Seagate 80 GB SATA Hard Disk.It will cost about Rs 3300.
The total Price is Rs 7200.It meets your budget.
GeekyBoy is offline
Old 28-02-2006, 11:39 PM   #3 (permalink)
U can upgrade HDD to 80/120GB 7200 rpm. Your ram speed we hope is 400MHz.
Make one dedicated partition for OS.
Padikkal is offline
Old 28-02-2006, 11:54 PM   #4 (permalink)
abhishek_sharma's Avatar
u have slow data transfer due to slow hdd, go for a new mobo which will support sata and buy a 80 gb maxtor or samsung hdd[sata]
i think with ur gfx card ona new mobo...the games will play just fine
abhishek_sharma is offline
Old 01-03-2006, 07:59 AM   #5 (permalink)
ymhatre's Avatar
Thnx
GEEKYBoy, Padikkal , abhishek_sharma
Ur help was really good
......Enjoy
Digit ROCKS
DusT = ME
ymhatre is offline
