Old 26-02-2006, 04:24 PM   #1 (permalink)
Default pink monitor!!!!!!
when i work continuously for more than half an hour my monitor starts misbehaving.
it suddenly acquires a pinkish tint and is present for some time, then flickers and becomes normal. what could it be? i've tried reinstalling the drivers but i dont think it's a software problem.
help me out, people
chiralvandal is offline
Old 26-02-2006, 04:50 PM   #2 (permalink)
abhishek_sharma's Avatar
try degaussing and v-moire
abhishek_sharma is offline
Old 26-02-2006, 05:36 PM   #3 (permalink)
thanx abhishek_sharma, but i've tried degaussing it. the problem isnt the type in which a part of the screen is pink(when there are magnets close to the screen) but that the whole screen goes pinkish, remains so for a few seconds or even a minute, then flickers back to normal.
Old 26-02-2006, 05:38 PM   #4 (permalink)
by the way what's v-moire?
Old 26-02-2006, 06:09 PM   #5 (permalink)
I once had a similar problem on my old Sony Trinitron 15sf Monitor, it was 5 years old and i used to slap the monitor to make the tint go away it worked well for a few days but then the tint started to change to green and later blue and again changed colors at regular intrevals... what dha hell!!....
... well my computer technician guy told me that it was my color IC chip or something thats got busted and he changed it and walla back to sweet normal mode infact better.....
hotdogXP is offline
Old 26-02-2006, 06:17 PM   #6 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Its nothing but only loose cable connector inside the monitor!
Once me too faced the same problem with my old Samsung 15' monitor and my system assembler just opened the monitor and fix the cable properly and the problem was solved!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 26-02-2006, 06:18 PM   #7 (permalink)
thanx ill try that and tell u.
and what's v-moire?
Old 26-02-2006, 06:42 PM   #8 (permalink)
and what's v-moire?
The V moire setting allows adjusting it from very visible to somewhat visible........
devarajan is offline
Old 26-02-2006, 07:19 PM   #9 (permalink)
Also check if there is any magnetic material near your monitor.Keep it at a distance.Transformers used for speakers also cause PINK colour on monitor.
susk21 is offline
Old 26-02-2006, 09:48 PM   #10 (permalink)
readermaniax's Avatar
hey ...i think the moniter wire is loose .... try n tell if this solves the prob
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
readermaniax is offline
Old 26-02-2006, 10:02 PM   #11 (permalink)
::vicky::'s Avatar
i have heard that there is a preset in picture tube which after some yrs end then ur monitor starts behaving like this
::vicky:: is offline
Old 27-02-2006, 12:00 AM   #12 (permalink)
Rubik's Uncle!!
Charan's Avatar
Vishal is correct . its just a loose cable. may be even the VGA port cable. nothing more than that . It happens if any of the three color signals doesnt go to the monitor(RGB).
Charan is offline
Old 27-02-2006, 01:18 PM   #13 (permalink)
thanx guys. i thought it was something like that since earlier i would fiddle about with the wire connecting the monitor to the pc and it would become ok but now it doesn't respond to that. maybe the connection has become a bit too loose for that kind of treatment. i'll call my technician and tell you the results when he completes the job. its a hp comp and those guys might take some time about it to do the job.
