Hello members ,
Whenever I try to save large number of files to the external drive ( with USB2 casing and Barracuda 80 gb disc ) , I get the message
Windows Delayed Write Failed . The external drive gets disconnected from the system .
My computer is with Athlon 64 3200+ , Asus A8N-E + xfx 6200 gr card , 1 gb RAM and windows xp sp 2 .
I did try by disabling the caching for the drive but that did not help . Searching the net , it seems not to be a very uncommon problem . Since there are many suggestions , it is confusing . What I understood is that , it is an issue of speed of the data transfer and intake . In this regard atleast one reference I got was
All I had to do was connect the 250 gb drive internally through the IDE interface and the data transfer was flawless.
Please help ( and thanks in advance for ur replies ) .
