Old 25-02-2006, 10:49 AM   #1 (permalink)
Default hElp mE to upgradE
Guys
Iam planning to upgrade to a 64bit AMD system
My choises are
AMD Athlon 64 3200+ 939 PIN Venice CORE
ASUS A8N-E
512MB DDR 400 Transcend Memory
GFX >> need help
So ppl i have many problems here
1st plz tell me the rates for the above if u pl have
2nd my dealer in nasik sayin ASUS A8N-E is not available its discontinued sp pls tel me if its rite or if u know where in mumbai pune i can get htis board
and if possible tell me the substitute with price
3rd i can afford 6200 pcie card sp tell me all the details u can give with rates and manufacturers for 128MB and 256 MB
GUYS PLZ HELP AS SOON AS POSSIBLE
ragsbava is offline
Old 25-02-2006, 02:34 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
check the sticky for hardware prices
and i suggest goin for 3000+
and buyin more RAM or a better GFX card with the saved money
vijay_7287 is offline
Old 25-02-2006, 06:06 PM   #3 (permalink)
abhishek_sharma's Avatar
512 mb ram for 2500 or 1900-2100 for hynix
amd 3200+ 7850
amd 3000+ 6400
asus a8n-e board -5700
gfx card 6200 128 mb>>> 4000
256 mb >>> 4500
abhishek_sharma is offline
