Old 23-02-2006, 10:35 PM   #1 (permalink)
Wise Old Mouse
mrintech's Avatar
Default SUGGEST GR8 T.V TUNER CARD
Dear friends,
My P.C configuration is as follows:
Motherboard: Intel D845 GVSR
Hard-disk: Seagate 80 GB
Processor: Pentium 4 2.4 GHz
Ram: 512 DDR
According to my P.C configuration, suggest a gr8 T.V tuner card!!!
What about clarity and resolution? I own a 17” L.G Flatron moniotor (E700SH)…. Let me tell about clarity and resolution of the card you suggest.
Moreover, how to convert my P.C into a Media Center One (neglecting the DVD Drive).
Please suggest soon.
- Mrinmay Bhattacharjee, mrintech, 9300764178
- MrinTech :)
mrintech is offline
Old 23-02-2006, 10:47 PM   #2 (permalink)
abhishek_sharma's Avatar
buy a pinnacle pctv solution, expensive but gr8 performance, clarity and recording...
abhishek_sharma is offline
Old 23-02-2006, 11:21 PM   #3 (permalink)
Wandering in time...
Ankur Gupta's Avatar
I bought a pixel tv tuner card a couple of years ago and am not satisfied with its performance.
the clarity is not gud and functions are pretty few.
u shud go for pinnacle.
have hrd gud reviews abt thm and i have seen the picture quality at my frnds house who owns one-it is pretty decent.
Ankur Gupta is offline
Old 24-02-2006, 10:05 PM   #4 (permalink)
Hi!
U can look for COMPRO TV/PVR FM..with FM audio..i currently have this card...exceptional picture quality....supports recording in mpeg2(dvd format) and mpeg4( divx) too....340 channels.....
cost abt: Rs.2000..
Available at: Mediatech, Andheri...or Lamington Road - Shop Next to PC Guide...or Maybe PC GUide...i don't remember exactly...
netbakwas is offline
Old 24-02-2006, 10:20 PM   #5 (permalink)
yeah..........pixel view sucks
i had it too
dont go 4 it
PINNACLE IS BEST
Captain Crime is offline
Old 26-02-2006, 05:15 PM   #6 (permalink)
sidewinder's Avatar
Pinnacle pctv sterio
And for a cheaper choice TechComm Tv pro. Its great ,offers realtime mpeg4 codind.Costs around Rs 1100
Bombina rocks
sidewinder is offline
Old 27-02-2006, 01:27 AM   #7 (permalink)
agreed.
I too have a PixelView Card. One of the main problems with the card is that the bundled software isn't worth a damn. If you get this card, make sure you use 3rd party software like InterVideo WinDVR.
I think you should buy an external card unless you intend to do some recording. At first, i thought wow! record shows that's gonna be awesome. but i got pretty turned off by the quality of the recording and the size (pixelview's bundled software records in AVI with no compression (?) and results in 100 MB file per minute of recording). So far i have yet to record a single show with my TV card.
better if you buy card from another company.
kanak is offline
