Old 23-02-2006, 03:31 PM   #1 (permalink)
Default only 10 MBPS max speed out of 10/100 MBPS NIC????
hi,
we now a days normally see that NIC cards having 10/100 MBPS speed marks. now we get max of 10 MBPS only, where has this 100 MBPS gone. is it that its just for name sake are can we expolit it which is hidden in settings
somewhere???
pls enlighten me...
aken
taken is offline
Old 23-02-2006, 04:40 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Just install the correct drivers, that will work.My comp shows my NICs speed as 10Mbps when the modem is off. but when i switch on the modem the comp recognises it as a 100 Mbps NIC. And if u want to change the speed just open your NIC's property page in device manager goto advanced tab. now select Link speed/Duplex mode and now u can change the speed settings.
Charan
Charan is online now
Old 23-02-2006, 06:19 PM   #3 (permalink)
Default Re: only 10 MBPS max speed out of 10/100 MBPS NIC????
Originally Posted by taken
hi,
somewhere???
pls enlighten me...
aken
u got it all wrong "Taken", NIC's are available @ 10/100 Mbps and not 10\100 MBps.
B----->Bytes
b----->bits
The actual speed u can get from the 10/100 Mbps card is " 100/8 =11.11MBps. u say that u get 10MBps which is perfectly alrite
I had this confusion earlier, not any more.
Andyiz is offline
Old 23-02-2006, 06:32 PM   #4 (permalink)
but in case ur nic card is working at 10 mbps then u'll b getting max 1111 kBps download speeds and not 11.1 mBps as in the case of 100 mbps
manmay is offline
Old 23-02-2006, 07:29 PM   #5 (permalink)
dude_where_is_my_doll
Posts: n/a
B----->Bytes
b----->bits
He knows the difference between Mbps and MBps .
Actually the Data transmission whether 10Mbps or 100Mbps depends upon your LAN type which is setup by LAN admin.
Old 23-02-2006, 09:18 PM   #6 (permalink)
it also depends upon the lan wire..
i hav seen some cat5 which do not support 100 mbps
hey what abt cat6 nebody seen or used them...
ne diff?
manmay is offline
Old 23-02-2006, 09:26 PM   #7 (permalink)
champ_rock
champ_rock's Avatar
most of them r same...... i tried 2 of them basically it will depend on network traffic also......
Registered Linux user number 400618
champ_rock is offline
Old 01-03-2006, 11:57 AM   #8 (permalink)
Default reply
u meant 1.111mBps, didnt u ?
Andyiz is offline
Old 01-03-2006, 05:21 PM   #9 (permalink)
@andyiz
1111 kBps is == 1.111 mBps isnt it?
nic 10 mbps will give a baud rate of 1111kBps==1.11mBps approx
and nic 100mbps 11.11 mBps
this is theoritically
practically 80-90 % of theoritical speed is reached.
manmay is offline
Old 01-03-2006, 05:42 PM   #10 (permalink)
Default reply
@manmay
hey dude, i apologize,i read it as 1111MBPS
tnz for correcting me
Andyiz is offline
