21-02-2006, 10:53 PM
DVD Writer Lens Cleaner
Hey guys i have been having some odd problems with my Sony DVD Writer DRU-A710(which i bought a year ago).I think its the lens which is giving problems.I was thinkin to clean it using a DVD-Cleaner DVD.Will that work for a Writer? If not suggest me some good ideas??
Thanks
Earth is full.Go home.
22-02-2006, 07:16 AM
it will work...go ahead
Bombina rocks
22-02-2006, 04:04 PM
do u work in a dusty environment??If yes,then buy one it will cost around 60-100 bucks.
23-02-2006, 09:41 PM
actually i am so apprehensive because earlier my CD Writer got screwed up because i cleaned it with a standard CD Lens cleaner.It messed with some thing and i started getting some error "power caliberation error".So thats y i was not so sure.Is there a special cleaning DVD for Writers?
23-02-2006, 10:55 PM
If I use my wife's perfume to clean off the dust from the CD/DVD tray will there be any problem?
I ran out of spirit once...oh and what about using alcohol (booze)?
23-02-2006, 11:13 PM
You can use sprays, but it depends on the alcohol content. Too much of anything is not good. What's the problem you're facing with your DVD writer anyway ?
23-02-2006, 11:18 PM
Wandering in time...
U shud try cleaning the lens if u know how to do it.
and for some other ideas u cud try upgrading the firmware of ur DVD-Writer.
24-02-2006, 11:08 AM
Thanks guys,
No problem. Just wished to know about the spirits that can be used to clean off the dust on the CD tray.
24-02-2006, 01:58 PM
Web Junky 2.0
Don't do that. It may cause some problem.
More reason to love orkut
Get Scraps, Testimonials and many more...
http://loveorkut.com/
24-02-2006, 02:18 PM
Web Junky 2.0
Don't use any ordinary lence cleaner,which provides some liquides with it. Buy a good lence cleaner with soft brush on the disk to remove the dusts.
24-02-2006, 02:24 PM
Web Junky 2.0
The liquid contains only alcohol[100% pure] will work. Any other mixure such as deo etc. will damage.
24-02-2006, 02:34 PM
Web Junky 2.0
Thanks guys,
You can clean the tray.
26-02-2006, 11:40 AM
Re: DVD Writer Lens Cleaner
Thanks
Hi, in also incidently have same writer, and is not working now at all, i used some cd lens cleaner-- chinese make and my writer is screwed up. also try upgrading the firmware version, the default is 1.0a but there is advancement for 1.0b or maybe new one might have come.
Dont worry its not only your drive, many resellers have told me this version has had serious problems, so the whole series is having the problem.
Poor Guys all the owners who got defective pieces of this!!!!1
09-03-2006, 08:01 PM
can anyone please tell me how to upgrade the firmware of my DVD Writer that is SONY DVD RW DW-Q30A. Currently it displays YYS3 in Nero Info Tool. I'm I using the latest version?
09-03-2006, 08:44 PM
@priya u can check manufacturers website
09-03-2006, 09:18 PM
adrable writes ::
i also get same error on nero sometime ago , can anyone tell me what is "power caliberation error" ??
" :arrow: CONNECTION BETWEEN LIFE AND TECHNOLOGY " is my topic of research !!!!
don't believe and respect any authority with closed eyes other then almighty !!!!! :idea:
09-03-2006, 10:19 PM
Originally Posted by mohit sharma
adrable writes ::
that error occurs when the media has worn out.
