Old 21-02-2006, 10:53 PM   #1 (permalink)
Default Upgrade trouble
i have an Intel P4 1.6 ghz pc with 640 mb ram.
I would like to upgrade my pc to an AMD Anthlon64 3000+ and would be using a new motherboard ofcourse from ASUS
http://in.asus.com/products4.aspx?l1...43&modelmenu=1
However i was wondering, whether mine existing RAM would work on this motherboard or not???
Thanks for reading.
nitinjavakid is offline
Old 04-03-2006, 11:11 AM   #2 (permalink)
The Hardware Labs
mohit's Avatar
@Nitin
ya your existing RAM will run perfectly on this Mobo since it accepts DDR RAM .. I am assuming you are using DDR RAM currently. But keep in mind there is no onboard VGA on this board and you will need to buy a separate Video Card (AGP 8X) for it. I dont suggest going for this board anyday .. Instead you can go for the ASUS A8N-E or A8N-VM.
mohit is offline
Old 04-03-2006, 11:26 AM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
ASUS a8ne doesnt have onboard gfx either
so the best option is to go for ASUS a8n-vm
it also comes with a PCIE expansion slot
but all this will work only if ur existin RAM is DDR
first make sure abt this
vijay_7287 is offline
