Old 21-02-2006, 05:45 PM   #1 (permalink)
Default iPod not recognized on computer, appears as removable drive.
I bought an iPod from a friend a few days ago, its an older one with no color, but has the single click wheel button.
So I tried to bring it to one of my friends houses to put some songs on it and it wouldnt show up on the left, and when you look for the iPod in my computer it shows up as removable drive. So we followed the steps on the apple website and the last thing it said to do was to resotre it to facotry settings.
So eventually that was able to happen, all the music was erased from the iPod, and the name and everything else was also erased. But the iPod still doesnt show up on the computer. It says I need to update the iPod, but when I go to the iPod updater it just sits there with 'intializing' as it fucntion, never moving.
All my friends have no trouble with their iPod, then when i plug mine in, it wont recognize it. Anyone ever have a similar problem, what did you do?
The last thing I think I am going to try is to bring it to a computer that has never had iTunes or an iPod and try and install it that way. Anyone else have any other ideas. Please respond.
Thank You.
Tallywacker is offline
Old 21-02-2006, 07:45 PM   #2 (permalink)
Chillum Baba
a_medico's Avatar
ipod will be detected as a removable drive... u can copy paste files. but it wont show while playing. ofcourse u can use this method to trasfer files from one comp to other..but thats it.
to play files and make them detect in ipod, u need to do the trasfer via itunes.
well thats jsut my personal experience. i have heard they format ipods and u can make them work windows way...but dunno abt that..also in that process u might end up damaging ur ipod.
itunes shud solve the problem
best luck.
a_medico is offline
Old 21-02-2006, 10:25 PM   #3 (permalink)
use the ipod formattin and restore utility provided with ur ipod
basically u need to falsh its firmware again ... and make sure u have itunes installed before u insert it after the flash .
u seem to have corrupted the firmware else if itunes is installed it shuld automatically start if the ipod is plugged in and detected.
No Mercy, No Limits.
theraven is offline
Old 22-02-2006, 11:25 PM   #4 (permalink)
 Macboy
goobimama's Avatar
You will need iTunes to transfer songs to your iPod. If you want to transfer to and fro, then use the iPod plugin for winamp...
I'm like a bird... :)
goobimama is offline
Old 23-02-2006, 11:09 AM   #5 (permalink)
Thanks all of you. very helpful indeed.
Old 27-02-2006, 01:19 AM   #6 (permalink)
Or if you use Foobar, then you can use the excellent foo_pod plugin.
kanak is offline
Old 03-03-2006, 03:04 AM   #7 (permalink)
Resident Weapons Expert
zombie's Avatar
Best tips are available on apple website. They have solution for almost every problem that you may face with your iPod.
Stalk, Strike, Survive.
zombie is offline
