Old 21-02-2006, 11:37 AM   #1 (permalink)
KKK
Default HELP!!! Processor Identity!!!!
I downloaded and ran CPU-Z latest version 1.32 and it shows that i have a Manchester core Athlon 64...which i know is absurd!!! i expected a Venice!
Also even after enabling C'n'Q from bios and Windows the processor does not underclock itself...nor its it stable when overclocked even slightly....my friend says that i have a Manchester witha faulty core sold to me as Veniec..is He right????
if so should i ask for replacement from my vendor???
my processor shows 41 C when started and at peak usage goes to 52 C
also i use a ASUS A8N-E mobo and it's temperature varies from 34 C to
46C ! are these temperatures OK?? Does somebody running the same config or similar has lower temperatures???
KKK is offline
Old 21-02-2006, 01:37 PM   #2 (permalink)
Manchester United
abhijit_reddevil's Avatar
If you have venice core, then kindly look into the box of the processor, it should say ADA3000BPBOX. That is the verification of Venice core. If the processor is under warranty, then you might as well ask for a replacement by showing the CPU-Z results.
By the way, I think the temperatures are normal. After playing Doom3 Ultra quality for around 3 hrs, the temperature that was shown in ntune and Asus PC-probe was around 52 deg, the A8N-E temp was 50deg and the GPU (6800GS) temp was 49deg. The temperature quickly falls to around 41deg after doing other mundane 2D tasks. I think your temp is normal but get the CPU replaced.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 22-02-2006, 12:40 AM   #3 (permalink)
KKK
Default thnx
thnx for reply!!!
KKK is offline
Old 24-02-2006, 07:07 PM   #4 (permalink)
darklord's Avatar
Actually Manchester is the core name for the AMD Athlon 64 X2 [Dual Core] CPUs that have 512Kb cache for each core.
darklord is offline
Old 24-02-2006, 09:12 PM   #5 (permalink)
KKK
So whats your point????
what am i to do ????
i have single core processor and it shows Manchester......no one out there who can help me enable the second core....if there is!!!
KKK is offline
