Old 20-02-2006, 02:09 PM   #1 (permalink)
sourav's Avatar
Default Can I change my chipset?
I have bought a new computer. It is Intel D915GLVG which uses 915 chipset. Will it support PCIe x16 because above PCI there is written PCIe x16 and has some pin which have been soldered(soldering).
Can I Intel Pentium 4 Extreme Edition run on my computer?
Can I Intel Pentium 4 Extreme Edition run on m computer by changing my chipset to anyother chipset and BIOS?
I have another CPU, that is Intel pentium Celeron 735 Mhz with its motherboard. Can I join this two computer and gain extra power?
We must accept finite dissapointment. But we must never loose infinite hope.
sourav is offline
Old 20-02-2006, 02:53 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Yes you can run extreme edition in this motherboard. but before you install the new processor update your bios to the latest. chk out www.intel.com for more information.
No you cannot change the chipset because its soldered to the motherboard.
It might be possibe at a higher level but not for smaller computers i guess. you just cant connect a cable between the two and use the processing power.
Charan is online now
Old 20-02-2006, 03:18 PM   #3 (permalink)
Learner
Kniwor's Avatar
No buddy... it is not possible to change ones chipset.. u will need to change the mobo itself... neither can u get the added power or something...
Kniwor is offline
Old 20-02-2006, 09:35 PM   #4 (permalink)
phatratt's Avatar
the chipset is soldered to the mobo,so don't ever think of changing the chipset,just get a new mobo else update u'r existing hardware drivers.
phatratt is offline
Old 04-03-2006, 02:36 PM   #5 (permalink)
sourav's Avatar
thanx all of you. as my exam was there i could not see. it's sad that i cannot join this two computers.
but however it could be possible.
sourav is offline
Old 04-03-2006, 02:56 PM   #6 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
do u mind tellin us how, it is possible
vijay_7287 is offline
Old 04-03-2006, 03:27 PM   #7 (permalink)
sourav's Avatar
i don't know. as you know nothing is impossible. i feel it could be possible
sourav is offline
