Old 19-02-2006, 10:59 AM   #1 (permalink)
WOW... are you?
gsoul2soul's Avatar
Default RAM check!!!
How to... and is there even a Software that i can use toi Check my nw RAM 512 Stick
I don't know... but my system has crashed 5 or 6 times... till now... since i updated my new ram.... I mean... that dreaded blue screen...
So... help ?
bye... Gsoul
PS: i use... onboard graphics, and when i used Klite codec - Classic media player it crashed !!!
when i tried using a Screensaver (3D) it crashed
and once... when i just was shutting down my system.. it crashed!!!
but hasn't crashed when... im using DVD or Adobe photoshop CS (i opened huge files)
gsoul2soul is offline
Old 19-02-2006, 11:01 AM   #2 (permalink)
WOW... are you?
gsoul2soul's Avatar
HELP !!! me...
Old 19-02-2006, 11:09 AM   #3 (permalink)
nishant_nms's Avatar
Use memtest from www.memtest.org or www.memtest86.com.
Note- These are diffrent softwares. I will suggest to use both of them. And at least give 2 passes before closing the test.
nishant_nms is offline
Old 19-02-2006, 04:25 PM   #4 (permalink)
Learner
Kniwor's Avatar
memtest86 is enuf i think...
Kniwor is offline
Old 19-02-2006, 09:50 PM   #5 (permalink)
bit
bit's Avatar
if you can get hand on registered version of GoldMemory 6+ then try it. It's awesome.
bit is offline
