Old 19-02-2006, 12:49 AM   #1 (permalink)
muralikrishnan's Avatar
Default For IBM Hard Disk How To Remove Bad Sectors
Hi,
I have IBM hard disk that my friend gave to me.In that some bad sectors formed form booting itself it will scan the Hard disk Drive C: has no problem but When D: drive started it Reach 84% to complete the process after wards it will fix the bad sectors i cant fully completed the bad sectors.
what can i do if i will Esc the step the next time i boot the Hard Disk says Warning:Back up your data or you will Loose your data it will say like this.
Tell me a solution......................
muralikrishnan is offline
Old 19-02-2006, 11:58 AM   #2 (permalink)
bad sectors are physical damage to the hard disk and they can't be removed so best option back up the data to prevent accidental data loss....
dabster is offline
