| Forum |
#2 (permalink) |
dude!! you will get an external USb casing for RS 700/-.
you can also connect you CD & DvD writer in it. Check if it supports USB 2.0(faster speed!!) But if you dont have an HDD to boot from, then how will you start your computer? I am not sure about this But if you still want to do so then try knoppix.The os which runs from CD!! check if it supports usb devices!! If this works:: WALLA!! Cnverted from InTeRnAl to ExTeRnAl Enjoy!! |
#4 (permalink) |
on looking at this thread just gave me an idea to make use of my old 40GB IDE PATA HDD(currently iam using 2 SATA drives)....
guys we just need a free USB port...thats it ??? lemme search on ebay and hen i'll look for it in nehru place!! |
#5 (permalink) |
Wire muncher!
yeah, if possible get a usb2.0 casing. connect it to a usb2.0 controller supported port and thats it!
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#9 (permalink) | ||
Core i7 (nehalem) Owner
infra_red_dude wrote:
amitsaudy wrote: Quote:
cheers n e-peace.....
Core i7-920 MSi X58 Pro-E Corsair 3x1GB Tagan BZ1100 GTX280 SSC+MSi N580GTX TWIN FROZR II/OC WD 1TB 22" Samsung 2233SW APC SUA1500i UPS Core i7:thinkdigit.com/forum/showthread.php?t=110397 |
#10 (permalink) |
@ashu888ashu888,check out this link... have lots of cases...
http://www.npithub.com/product/pt_view.php?pcatid=1134 |
#14 (permalink) | |
lets hope for the best !! i also purchased 50 blank DVD's Local Brad...for 450/- ...comes down to 9rs per DVD ... !! have burned 3 down...looking god till now... |
#16 (permalink) | |
nd dont compare ur moserbaer with my local unbrabded one... they are not comparable... the pack of 100 DVD's frm Moserbaer were for 1550/- ! |
#19 (permalink) |
ok is it better to buy a 5.25" enclosure (as it has a fan), and use a mount to keep the 3.5" drive secure in it
OR to buy a 3.5" enclosure (no fan) @ashu Regarding the difference in speed, there is definitely a latency involved, but it isn't noticable if you use USB 2.0. If on the other hand if you use USB 1.1, then your transfers are gonna take forever |
#20 (permalink) |
I have 3 USB2 cases (2 x 3.5" and 1 x 2.5") and 2 USB2IDE cables and I have found the Vantec cases the BEST - the Vantec 3.5" case cost me 2500/- ... I think it is worth it to get this case. The other 3.5" case I have is the BAFO which does not recognise HDDs larger than 127GB.
Regarding speeds..... when I have my 2 HDDs conntected to the computers Controller I get a data transfer speed of around 48mb/s when I move one of these 2 HDDs to a USB2 case the data transfer speed comes down to 24mb/s The USB2 2.5" case with a Seagate 20GB 5400RPM HDD gives me 11mb/s This same Seagate 2.5" HDD when connected to the USB2IDE cable gives me 18mb/s The Techcom USB2IDE cable is not good. The one to buy is... http://www.dansdata.com/rdriver.htm I got one of these from Lamington Road for 650/- 6 months back - I heard it is a bit cheaper now. The advantage of this cable is that it takes 2.5" and 3.5" HDDs as well as Optical drives and writers. |
#21 (permalink) |
The Frozen Nova
Hey, u people bought the usb casing. Does it boot from the usb Casing??
I dream of a better tomorrow... where chickens can cross roads and not have their motives questioned. www.nerdweed.blogspot.com |
#22 (permalink) |
hey easy , i got " R DRIVER I " today .. which supports 3.5'' inch hdd and cd/dvd rom drives ... but has no support for 2.5'' inch .. for 375 rs from road side vendor at lamington road ..
now it is working very well with hdds but i am having no luck with odd drives .. could u pls help me in this regard .. what should be the jumper settings for odd drives .. master . slave or cable select ? pls help .. |
#23 (permalink) |
there arent any speed issues..... i use the same funda the 700 unbranded HD casing its usb 2 and it works jus fine and ..... all my games run frm tht hd and there are no performance issues so i dont think tht is too much of a bother
#24 (permalink) | |
#25 (permalink) | |
#26 (permalink) |
The Frozen Nova
I brought 1 casing yesterday, but it is unable to load the drivers. I read the manual, it said connect ur HDD to Master. Is it necessary to do so.
Also, when I switched the power off, it said "Loading of drivers complete. Please restart." Even after I restarted it didnt show my HDD. Ne help
#27 (permalink) |
I have 3 USB cases and 2 USBtoIDE cables and have never needed to install any drivers for XP. Even the Win98SE which runs on a HDD in a USB case did not require me to load any drivers.
Which OS do you use ? You should run XP with SP2 and there should ne no problem with the external USB drives. In XP you have to format the drive to get it to show in Windows Explorer - format the HDD from Disk Management of XP. Control Panel / Admin Tools / Comp Management / Storage / Disk Management HDD in a USB case should always be set as a Master drive. |
#28 (permalink) | ||
The Frozen Nova
I am using WinXP Pro SP2.
Will i have to repartiton Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
