Old 17-02-2006, 07:14 PM   #1 (permalink)
coolsunny's Avatar
Default wanna buy AMD64...help me
i want to buy AMD64 3200+
i have no idea which motherboard suits it best.Can anyone give me idea.
Did i need DDR2 RAM for best performance ?
Did AMD64 has heating problem. i have the buget of 18k for the three . :roll:
coolsunny is offline
Old 17-02-2006, 07:22 PM   #2 (permalink)
gxsaurav
Posts: n/a
I would suggest Gigabyte GA-K8N51GMF-9 for the motherboard, it comes with onboard graphics & PCIe slot, so best of both worlds
AMD64 does not uses DDR2 RAM, it will in the future but not now
Old 17-02-2006, 07:48 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
wats DDR2(400rpm)
i think u r talkin abt 400mhz and thts not DDR2
normal DDR RAM will give 400mhz
vijay_7287 is offline
Old 17-02-2006, 11:35 PM   #4 (permalink)
thunderbird.117
Posts: n/a
Default Re: wanna buy AMD64...help me
Did i need DDR2(400rpm) RAM for best performance ?
Did AMD64it has heating problem. i have the buget of 18k for the three . :roll:
u can buy Asus A8n-Sli Deluxe. It is MHZ not rpm(rotation Per minute).
Old 18-02-2006, 01:25 PM   #5 (permalink)
for onboard vga and pci-e slot i'll suggest Asus A8N-vm. 6100 onboard
ashnik is offline
Old 21-02-2006, 12:06 AM   #6 (permalink)
yaar don't u think it will go way out of his budget (18000 for all the items)
cause i have heard that it cost around 10500/-
notify me if i am wrong.
nd4spd is offline
Old 28-02-2006, 10:05 AM   #7 (permalink)
What about ECS KN1 Extreme it seems to be the best value for money and also a outperformer!!!
abhishekwithyou is offline
Old 28-02-2006, 08:29 PM   #8 (permalink)
coolsunny's Avatar
thanks for
suggestions
i can maximum spend 10K for motherboard
whats about
MSI K8N Neo Platinum---Won Digit Zero One Award 2005
MSI K8N Diamond----Won chip magazine best products of the year 2005. i think it costs more
Old 01-03-2006, 12:05 AM   #9 (permalink)
thanks for
suggestions
whats about
good mobo..I got the SLI platinum (Neo4 platinum)
advantages:
i) onboard Creative SB Live 7.1! audio
ii) SLI
iii) high overclockability
disadvantages:
i) High Price
ii) Can't think of anything else!
The K8N diamond has extra sata ports/ dual gigabit ethernet / more usb
than the Neo4 Platinum
A64 3200 winnie + 512*2 KVR 2.5-3-3-6 2T + MSI K8N SLI platinum - Creative SB Live! 7.1 + Leadtek PX6600GT 550/1125 + 160 GB Seagate N.C.Q. + 320 GB WD + LG 17" CRT
3Dmark05 - 4008 3Dmark03 - 8,983
Ringwraith is offline
Old 01-03-2006, 01:32 PM   #10 (permalink)
coolsunny's Avatar
thanks for
suggestions
whats about
advantages:
ii) SLI
disadvantages:
i) High Price
extra sata ports/ dual gigabit ethernet / more usb --what kind of advantage they give us.i think no advantage of extra sata ports & extra usb
"ii)Can't think of anything else" ----what does it mean
