Old 17-02-2006, 04:11 PM   #1 (permalink)
Default AMD Athlon 64 and Intel
No, this is not another of those AMD vs Intel threads, so don't start complaining to a mod already. As you see the best processor for a decent system at a decent cost now is AMD Athlon's 64 3200+, which comes @ 2.2 GHZ. While, Intel's neat and decent comes with Hyperthreading at 3.2 Ghz or so.
As you can see there is a 1 GHz difference but why is AMD still considered to be good?? Is the power the same? Also, is there any news on the 4800+ here?
Thanks
Master Search Engine Optimization Tutorial.
Sitez::
1) Broadband-O-Sphere
2) [url=http://techbulletin.net]TechBulletin[url]
Retro is offline
Old 17-02-2006, 04:24 PM   #2 (permalink)
kill_deep_singh
Posts: n/a
Default hi
amd is better.u know why there is 1ghz difference between amd and intel or intel produce high clock speed processors and amd not,becoz amd can do the same work at less clock speed at which intel do at highclock speeds.amd is far more better than intel now. for gaming i recommend amd and nothing else.
Old 17-02-2006, 06:14 PM   #3 (permalink)
The Hardware Labs
mohit's Avatar
Default Re: AMD Athlon 64 and Intel
Thanks
for your info both the socket 754 and 939 A64 3200+'s have a 2.0 ghz clock speed and not 2.2 ghz as written by u.
mohit is offline
Old 17-02-2006, 06:47 PM   #4 (permalink)
several hardware tests shown by reviewers tells that if the two processors are subjected to same stress the AMD processors runs at much lower temperatures than intel ones and hence they require less cooling that is y AMD is better
signature??? Let Me Think About It!!!
paul_007 is offline
Old 17-02-2006, 07:50 PM   #5 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
and more importantly they cost Lesser
vijay_7287 is offline
Old 19-02-2006, 08:07 AM   #6 (permalink)
So, you guys are saying even though there is a 1Ghz, difference the performance is the same? Hmm...Interesting. Any reason as to why?
Also, is there any Indian Hardware price compiling site?
Sitez::
Retro is offline
Old 19-02-2006, 10:18 AM   #7 (permalink)
These are the only two I know of :
http://www.techenclave.com/forums/hardware-prices.html
http://www.deltapage.com/
and Ofcourse the Sticky Thread : LATEST HARDWARE PRICES & QUOTES..!! in this forum
hotdogXP is offline
Old 19-02-2006, 04:37 PM   #8 (permalink)
Learner
Kniwor's Avatar
Clock speed is not all the criteria, the two processors have diffrerent architecture, both processor do not do the same amount of work per clock cycle, am AMD is programmed to do more than an in intel per clock cycles,
then there is also the cache layout,
on-die memory controller,
hypertransport etc.
Numerous factors that all add up.
http://kniwor.wordpress.com/
Kniwor is offline
Old 20-02-2006, 11:14 PM   #9 (permalink)
and what does the cache size shows about the proccy performance cos
INTEL 3.0 Ghz has........................2MB L2 cache
while
AMD Athlon 64 3200+ has.............512KB L2 cache
nd4spd is offline
Old 20-02-2006, 11:22 PM   #10 (permalink)
Learner
Kniwor's Avatar
Maore cache is better, but chache layout matters
Kniwor is offline
Old 21-02-2006, 02:12 PM   #11 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
As u have mentioned 3200+ amd proc, its usualy like this, 3200+ suggest that its equal or/and better than intel 3.2 Ghz proc. AMD procs work like two processoer working in tandem so even though clock speed is less the same amt of work is done in half the time( not exactly half but u can say that) as of intel proc....
wizrulz is offline
