Old 16-02-2006, 10:11 PM   #1 (permalink)
Manchester United
abhijit_reddevil's Avatar
Default Someone please help
Hi, just got my new AMD system (3000+, 1GB, 6800GS, 450W PSU, A8N-E). However, I am getting one warning message in BIOS startup-"your computer CPU fan fail or speed too low. You can also disable this message in setup." Press F1 to continue, DEL to enter setup. When I press F1, windows XP loads without any problems and operates without any problems.
How can I disable this message? I have searched the A8N-E BIOS and could not find it. It is bugging me...
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen
abhijit_reddevil is offline
Old 17-02-2006, 09:20 AM   #2 (permalink)
This is actually a silly problem occuring in most Asus A8N-E/SLI mobos, I had the same problem. You might have noticed this happens only when you start the computer the first run and not when yu restart it, I think its a sensor bug in the bios or something but Im not sure.
However the fan is working fine and nothing to be worried about unless you get a warning in the Asus Probe Software for windows supplied with the mobo installation cd, its a nice software shows yu fan speeds, power voltages, temp of cpu, mobo....etc...
To disable this warning in the bios, goto the bios->power tab->hardware monitor->Q-Fan Controller->Disabled.
cheers..
hotdogXP is offline
