Old 16-02-2006, 08:33 PM   #1 (permalink)
!FREEWARES!
Akshay's Avatar
Default Degause laptop monitor
i use compaq presario widescreen laptop model. Is thr a way with which i can degause d display as done in desktop models... Only brightness controls hav been given
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Akshay is offline
Old 16-02-2006, 10:04 PM   #2 (permalink)
Default Re: Degause laptop monitor
Degaussing is necessary only for CRT (cathode ray tube) based monitors and not LCD's (like what's used in your laptop). CRT's are affected by magnetic fields and the resulting colour imperfections can be corrected using the degauss option.
Cheers,
Keith
Keith Sebastian is offline
Old 17-02-2006, 12:01 PM   #3 (permalink)
!FREEWARES!
Akshay's Avatar
But den wht is d solution for clearing d screen of magnetic/some odr effects in laptops? I had recently faced this prb wherein my screen had some effects on d left side (dont knw d cause)and I had no odr option but to restart the machine.
MBP 13.3";
Akshay is offline
Old 17-02-2006, 11:40 PM   #4 (permalink)
 Macboy
goobimama's Avatar
the discolouration is caused by a faulty LCD panel.
I'm like a bird...
goobimama is offline
Old 18-02-2006, 09:47 AM   #5 (permalink)
How can u possibly have a magnetic build up in a liquid Crystal display screen????? The discoloration is due to the faulty panel....Its DEFINITELY not due to any stray magnetic fields....
HK
h_kunte is offline
