Old 15-02-2006, 11:35 AM   #1 (permalink)
Default DVD Region
Recently i purchased Gigabyte Combo Drive.
It was working fine until i accedently changed DVD Region in the Device Manager Properties in Windows XP.
Now drive don't detect DIGIT DVD's in win XP. drive detects DVD's in win 98. pls help me.
i have 98 on c drive & XP with sp2 on d drive
Bruce_Wayne is offline
Old 15-02-2006, 11:43 AM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Did u change the DVD REGION more than 5 TIMES ??? If yes, then 5th time is the max option that DVD REGION option has while setting the code for permanent use. see this www.hometheaterinfo.com/dvd3.htm for ur confusion.Check ur manual for setting back the region. BTW do u knw the original setting of ur DVD (b4 accidently changing the REGION)???
Also see this as its a helpful site:www.dvddemystified.com/dvdfaq.html
Post ur results too
cheers n e-peace......
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 16-02-2006, 09:41 PM   #3 (permalink)
Post ur results too
But how on earth can the Digit DVD be region coded?
Correct me if I am wrong!
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 16-02-2006, 10:34 PM   #4 (permalink)
V.Prem Kumar
Its not about DIGIT DVD or sum other DVD, i jus said that since he changed the DVD region in his DVD by mistake so that will not detect (play) the DVD made in this region.
AFAIK, Basically all DVDs are region dependent (same as we hv NTSC and PAL for Game CDs) therefore, if the DVD REGION is changed (by default or by mistake) it will not detect any of the DVD (i repeat) It will not detect ANY of the DVDs of that particular region...
Cheers n e-peace.....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 17-02-2006, 07:11 AM   #5 (permalink)
V.Prem Kumar
Again I would like to know for sure whether DVDs like those of Digit are region coded? If so, why should it not work in his player even if all the 4 regions are used up.
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 17-02-2006, 03:32 PM   #6 (permalink)
royal's Avatar
hey Bruce_Wayne ...
U could try DVD region free
http://www.dvdidle.com/dvd-region-free.htm
sometimes upgrading the firmware of ur DVD drive also helps...
though u gotta be absolutely sure that u know what ur doing
normally updates r available from manufacturer's website
royal is offline
Old 17-02-2006, 07:48 PM   #7 (permalink)
dIgItaL_BrAt's Avatar
Only Video-DVD's are region coded,not data DVD's.
dIgItaL_BrAt is offline
Old 18-02-2006, 12:48 AM   #8 (permalink)
This was what I was trying to convey through my posts.
But of course I was not 100% sure.
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 22-03-2006, 06:50 PM   #9 (permalink)
The Frozen Nova
casanova's Avatar
Hey, u can even contact ur manufacturer, read ur manuals, it says if u need help changing your region more than 5 times call at a particular no. I own a samsung dvd writer, hence can't give u the no.
Also, try using "DVD Region CSS Free", it is a shareware
www.nerdweed.blogspot.com
casanova is offline
- by bhaskar
- by Deepaks
- by Anorion
