| Forum |
#1 (permalink) |
#2 (permalink) |
Core i7 (nehalem) Owner
As u hv said that ur Combo drive is working fine on other system, then i would recommend that u please check the power connector and the IDE cable that goes into the Combo drive. BTW, did u plug the Samsung drive with the same power connector and/or IDE cable (that was holding ur COMBO) ?? I guess tat cant be possible (if u are saying that ur Combo is fine). I guess its the power connector problem.Please post other details of ur system like ur OS and wether ur using SP2 or wat service pack (related to the OS version ur using)..
Cheers n e-peace......
Core i7-920 MSi X58 Pro-E Corsair 3x1GB Tagan BZ1100 GTX280 SSC+MSi N580GTX TWIN FROZR II/OC WD 1TB 22" Samsung 2233SW APC SUA1500i UPS Core i7:thinkdigit.com/forum/showthread.php?t=110397 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
