| Forum |
#1 (permalink) |
It used to run perfectly before, having 2 partitions g:\ and f:\, but now it doesnt recognize them. It happened yesterday when i was tweaking my pc from this site: http://www.neowin.net/forum/index.php?showtopic=235571 I made the following changes: 1. Right click on 'my computer' > select 'properties' > Go to the 'hardware' tab and select 'device manager' to open the device management window. Expand 'IDE ATA/ATAPI controllers' and highlight the 'primary IDE channel.' Right click the highlighted entry and select 'properties.' Go to the 'advanced settings' tab. and so according to the post. But i reverted it back to default but still nothing happened. 2. DISABLE UNUSED PORTS & DEVICES This also, reverted by system restore. However, when i open up Partition Magic, it shows the second disk but as 76GB unallocated. What happened to my data(about 40GB) and my two partitions? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
