Old 14-02-2006, 09:23 AM   #1 (permalink)
jacques's Avatar
Default computer is taking restart
I AM USING P4, RAM CAPACITY 256, OS WINDOWS XP, WHEN I START COMPUTER IT TAKES REBOOT AFTER SOME TIME AND THEN NO DISPLAY COMES ON SCREEN. PLEASE HELP..............
jacques is offline
Old 14-02-2006, 01:34 PM   #2 (permalink)
alib_i's Avatar
it could be anything ...
Loose electrical contacts
Loose RAM modules
Also try this ..
Go to .. My Comuter(right click) -> Properties -> 'Advanced' tab
Under 'Startup and Recovery' click on 'Settings'
Under 'Sytem Failure', uncheck 'Automatically Restart'
This will prevent computer from restarting under the condition of a BSOD (Blue Screen) ... it will stay at the blue screen and you can note down the details about the error before restarting.
Note it down and post here.
alibi
-Metallica
alib_i is offline
Old 14-02-2006, 08:45 PM   #3 (permalink)
phatratt's Avatar
do u get any series of beep codes while switching on u'r PC???
phatratt is offline
