Old 11-02-2006, 08:59 PM   #1 (permalink)
Default Connecting a TV Tuner Card... !!
Hey Guys...
to start with i am trying out a pixelview TV Tuner card for the time being,and if things work ou fine i'll be going ahead with compro videomate PVR/FM
installed the card...everything is working fine except audio.
have 915 board,with creative 6.1 speakers...
have a look at the audio ports ( sorry abt a lil dark pic..)
here i connect my three leads to the creative speakers....
here is the back of the pixelview TV Tuner Card...
and here is the cable that is given to be connected to line in on motherboard from TV Tuner's Audio Out....
rite now i have connected speakers directly to Audio Out ( old 2.1 speakers) and the sound is coming fine but while recording the sound wont be recorded... so is there any way for it...bcoz if it isnt then iam not going ahead with any new TV Tuner Card....
grinning_devil is offline
Old 12-02-2006, 01:42 AM   #2 (permalink)
shashanktyagi1's Avatar
well i also had pixelview and the connections are alright. but tell me how r u recording. i also tried to do that with pixelview but thay wasnt any sound(even pic quality was poor). so if u find tell me the way. i will also try to reconnect my wires.
shashanktyagi1 is offline
Old 12-02-2006, 02:07 AM   #3 (permalink)
hey MAn...Connect To Line IN...In Recordin..
N Off the AUX..
Chindi_Chor is offline
Old 12-02-2006, 06:31 AM   #4 (permalink)
@Chindi_Chor , look at the first pic posted.
In which port u want me to connect the cable frm TV Tuner Card?? For ex lets assume i plug it in the first one,then the audio looses the front speakers as all three ports are consumed by 6.1 speakers
Old 13-02-2006, 06:52 PM   #5 (permalink)
Default same problem dude
i have also da sam problem .i can record videos with no voice,i think 915 doesn't supports pixelview.my old 845g doen't show this type of problem
nvidiasingh2006mb is offline
Old 16-02-2006, 09:06 PM   #6 (permalink)
Are u trying to record from a VCR or handycam ? Your speaker connection of the PCTV card is for input or output ? If for input then connect the audio from the cam to it , If u have already done this try to connect the audio out to the MOBO microphone input , It should work now . I use a PCTV 100e USB2 from Pinnacle , It works fine, though a little slow.
Huzefa is offline
Old 17-02-2006, 06:51 AM   #7 (permalink)
sidewinder's Avatar
well it seems u are running out of audio ports...
U shd better go for a separate sound card woth dedicated port.
Hav a look at creative SB 24 bit 7.1 series ,.It costs around 2k nd will solve ur problem
Presently u cant connect it to ur mobo
Bombina rocks
sidewinder is offline
Old 19-02-2006, 12:37 AM   #8 (permalink)
i dont think that will solve the issue also...
u see as soon as i plug in the sound card,my onboard sound will be disabled..
so i'll be back on ground zero !!
i wont be able to use 3 ports by onboard as well as by card!!
so basically it comes down to this ...
NO ONE WHO HAS 5.1/6.1 SPEAKERS USE TV TUNER CARD !!!!
Old 19-02-2006, 01:05 AM   #9 (permalink)
gxsaurav
Posts: n/a
if u can hear the audio, then just select the recording application, & select "Record for wave in"
Old 19-02-2006, 07:45 AM   #10 (permalink)
hear the audio ???
first tell me what shud be the physical connection like..
nd dont tell me that u have to plug in the audio cable frm TV Tuner to
audio in in sound card...
have a look at the pictures and tell me if it is possible..
which i dont think is...
but iam now very sure that no one who is using 4.1/5.1/6.1 speakers is using a tv tuner card....
Old 19-02-2006, 09:21 PM   #11 (permalink)
sidewinder's Avatar
I dont get u !!!!
When you plug in additional sound card..you should disable the onboard one from bios.Then Connect all youe speaker ins to the speaker ports of new sound card and connect the audio out cord from tuner to the line in port of your sound card.
Thats it !
Bombina rocks
Old 19-02-2006, 10:04 PM   #12 (permalink)
after this no ports will be left free !!
Old 20-02-2006, 06:52 AM   #13 (permalink)
sidewinder's Avatar
All u need is 3 speaker leads..right?????
Look at this pic man.This is the sound blaster Live 24 bit 7.1 card available for Rs 2000.The first three connectors are for ur speaker leads and the fourth one is the line in.
Hope this will clear ur doubts
Bombina rocks
Old 20-02-2006, 09:11 AM   #14 (permalink)
ohhhhhh...it has 4 connectors....it clears all doubts very well !!!
nything cheaper than this ????
2k....hmm...... :roll:
Old 20-02-2006, 06:13 PM   #15 (permalink)
sidewinder's Avatar
U can get a Sound Blaster Audigy value edition 7.1 24 bit for Rs 1600 nd normal 7.1 sb for rs 1350.
Confirmed price
If u want something cheaper then u can get frontech or Tech comm c media chip based cards costing fro rs 300 to 1000 but dont expect creative like qualty from them
Bombina rocks
Old 20-02-2006, 10:35 PM   #16 (permalink)
thanx a ton sidewinder...i'll try to get them ASAP!!
have just spend almost everything on numeric 1000VA UPS....
till then the thread can Rest In Peace !!!!!
Old 20-02-2006, 11:21 PM   #17 (permalink)
sidewinder's Avatar
as u wish !!!
Just a question...what would u run with a 1000 va ups?????AC machine
Bombina rocks
Old 21-02-2006, 01:50 AM   #18 (permalink)
600VA UPS always makes my system restart...
md herez the cinfig i have..
p4-3 Ghz
512 * 2 RAM DDR400
2 HDD SATA ( 160GB + 250GB )
2 Optical Drives (CD Writer/DVD Writer )
6600 PCI-Ex Graphics Card
17" CRT monitor
first i was going ahead with 800VA but the small amount of difference made me go for 1KV.
by the way how much do u think its for ???
Old 21-02-2006, 12:31 PM   #19 (permalink)
sidewinder's Avatar
well my sister seem to hav pretty similer config wto urs..but running fine with 600 va APC ups.
I think ur problem lies within ur PSU
How much ur 1 kva ups costs?
Bombina rocks
Old 21-02-2006, 04:56 PM   #20 (permalink)
i dont think anything is wrong with PSU...
got a new one just last month,powersafe 400 watts..
moreover the PC isnt restarting...
even if i turn off the monitor on backup and then turn it back on then also !!
costed me 5500 (including taxes)
Old 22-02-2006, 11:27 PM   #21 (permalink)
abhinavrakesh's Avatar
Default Here is Your Answer
Connect the audio lead with both ends having stereo pin to line in of soundcard and audio out of TV Tuner card then double click at the speaker i con in your system tray the uncheck mute option in line in then configure card for recording fron streomixer input or through line in the same problem i faced but now my card works file
connect audio lead to linein and audio out of TV Tuner uncheck mute option of line in configure TV Tuner to Record from Stereomixer input or from line in and there you've done
abhinavrakesh is offline
Old 22-02-2006, 11:41 PM   #22 (permalink)
Default Re: Here is Your Answer
cant understand even one sentence what u have posted...
its a WHOLE paragraph,u wont find any full stops,and not even any comma!!!!
nyways thanx for trying to help...
problem has been solved....!
