Old 11-02-2006, 06:22 PM   #1 (permalink)
Default SATA and SATA 2
Hi,
Is there much diference between SATA1 and SATA2 in perfomance
What is the cos of SATA2 hard disks
anilthomas26 is offline
Old 11-02-2006, 08:34 PM   #2 (permalink)
phatratt's Avatar
main difference is data transfer speeds SATA 1 has 150mbps and its lot faster on a SATA 2.I don't have much info on SATA2.
phatratt is offline
Old 11-02-2006, 08:38 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
SATA-2 can give u performance of almost 300mbps
but thts just theoritical
it mainly depends on the HDD spindle speed
so the real time difference between SATA-1 &2 wont be noticible
vijay_7287 is offline
Old 12-02-2006, 02:01 AM   #4 (permalink)
SATA 2 Is Much More Faster thn SATA 1..n the price is also Difference...
Chindi_Chor is offline
Old 12-02-2006, 02:23 AM   #5 (permalink)
El mooooo
eddie's Avatar
The speed difference is just theoretical as yet. Today's drives are not using even full SATA bandwidth i.e. 150 mbps but SATA-2 is definitely the future. We will see cheaper and faster SATA-2 drives in future so if you are planning to buy a Motherboard then buy one with SATA-2 ports instead of SATA-1. You can use SATA-2 drives when they actually start using the full or at least a part of SATA-2 bandwidth. Till then just use SATA-1 drives. SATA-2 is backwards compatible so you'll face no problems in doing it.
eddie is offline
