Old 09-02-2006, 12:20 AM   #1 (permalink)
piyush gupta's Avatar
Default HDD Bad Sectors
Hi
I have a 10GB seagate HDD my prob is that whenever i try to make partitions on it I can't format it due to Bad Sectors
I tried Seagate's Low Level format & Zero Fill utilities but
it fails
Do this HDD is dead or I can use it anyway using any other s/w?
It still detects 10Gb on my PC
piyush gupta is offline
Old 09-02-2006, 12:40 AM   #2 (permalink)
The Hardware Labs
mohit's Avatar
no use using a hard disk which could not even be recovered by zero formatting.. it will keep posing problems for u and ofcourse your data will be on a high risk of loss if you use this drive.. dump it !!
mohit is offline
Old 09-02-2006, 04:16 PM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Suggestion- It is 10gb harddisk na.....do not dump it.....store it some where so that u can show ur grand childrens that 10gb hard disk existed
On a serious note get urself a new HDD as even if anyone repairs it it is gona be risky and expensive affair......and major risk for ur data , if u store any imp data on it
wizrulz is offline
Old 11-02-2006, 03:39 AM   #4 (permalink)
I think i m with some intelligent computer greeks with a never lose funda
but...
Old 11-02-2006, 08:41 PM   #5 (permalink)
phatratt's Avatar
even after lowlevel formatting failed then it must be physically damaged very badly,better get a new one.
phatratt is offline
Old 12-02-2006, 12:07 AM   #6 (permalink)
Thanx for suggesion I will buy a nweone
