Old 08-02-2006, 08:25 PM   #1 (permalink)
jacques's Avatar
Default cpu speed problem
Hi all
I m using P3 ,OS win98se, when i start the computer every time i get a msg that select Your CPU speed and press a key to boot. After pressing a key BIOS automatically get open. I m worried that have some problem in my computer. Plz buddy help me out.................
jacques is offline
Old 08-02-2006, 09:02 PM   #2 (permalink)
bang bang!
Chirag's Avatar
Same prob occured with my frnd. I told him to replace the CMOS battry with a new one. And after he replaced the prob was solved. So try changing the CMOS Battry.
Chirag is offline
Old 08-02-2006, 11:11 PM   #3 (permalink)
The Hardware Labs
mohit's Avatar
ya it seems like your bios settings are getting reset due to a drained out battery.. do replace the battery and confirm.
mohit is offline
