Hi everyone!
My budget is Rs. 40,000. Please suggest me a pc config suitable for gaming and multimedia applications. Hardware components should be available in Kolkata. my preferences are given below:
CPU:: AMD or Intel, for AMD 939 pins is must.
M'board:: For AMD 939 socket, SLI and onboard graphics support
RAM:: 512MB DDR 400
CRT:: 17" Flat or ...
Optical drive:: LiteOn AllWrite or any better DVD Writer
GraphicsCard:: One that fit in budget
other components are as usual as u think best.
Please refer to their prices if possible.
Thanks.
