Hey guys, I need some advice. I was thinking about buying a UPS, an 800VA one. I am thinking about buying either a Numeric 800VA or a Microtek 800VA (APC is way out of my budget). I am unable to decide between the 2, as I don’t have much experience with UPS buying, and information about either UPS isn’t clearly available.
I want the UPS for the following configuration:
Samsung SyncMaster 753s 17� Monitor
P4 2.4c + 865GBF MoBo
512MBx2 DDR400 Kingston RAM (1GB total, in dual channel)
XFX GeForce 6600GT 128MB DDR3
Seagate 80GB Barracuda
Sony Q28A DVD-RW
Supercomp 400W SMPS
2 extra 80mm fans
Realtek NIC
I want a UPS that will provide at least 15mins of backup time, with the above configuration. The more the better. Which UPS will be the better one? Which one will give higher backup time. I want to know the user experiences or any problems that you guys have faced with either UPS.
If there is anyone using BSNL’s DataOne service, who has either of these UPS, I would like to know if the modem resets (restarts) if there is a power cut and the UPS switches to battery power. With my older UPS (Elnova 500VA, very old) the modem used to reset whenever there was a power cut.
I also wanted to know something about the Microtek UPS. The one called dual power. Does it come with 2 batteries installed by default? Does the backup time really double? How is the Microtek UPS generally? Any problems/does it go bad quickly? I normally don’t like Microtek stuff, but a UPS is something too complicated, so…
Guy, please help me out here. I want to buy the UPS in a couple of days, and any advice would be highly appreciated.
